Posted 27 June 2013 - 08:12 PM
Posted 28 June 2013 - 10:10 AM
Maybe you could ask a mod to move it for you?
Posted 19 July 2013 - 09:18 AM
.. bareing in mind its a fully reatored, show car, used very rarely, and gonna be used for the odd blast, down the odd country road, but more to make the noise t the shows, and wouldnt mind a bit of poke to go with the rest of the car to make it a propor show piece..
It depends on what diff you gonna use, hot cams with a narrow power band need a short diff to keep it on cam at gearchange. A good alternative will be swapping the gear set with a close ratio set (which is still highly reccomendable if you swap the diff for a 3.76 or higher to have a taller 1st gear that makes is more drivable).
A Kent MD276 should be fine for that, a 286 or a swiftune SW10 will be even better if you dont mind rebuilds at about 10k miles
Also tagged with one or more of these keywords: clubman, roundnose
Projects →
Mini Saloons →
1976 Mini 1000 Le "stripey"Started by cafeclassic , 03 Sep 2025 |
Projects →
Mini Saloons →
Black 1979 1275GtStarted by StuaR32t , 15 Feb 2025 |
Projects →
Mini Saloons →
Mini Cooper Project - Finally StartsStarted by piphatch , 08 Jan 2025 |
Projects →
Mini Saloons →
1965 Austin Mini Restoration - Canadian Mk1Started by DoubleEh , 14 Nov 2022 |
Projects →
Mini Saloons →
Project Joe - 1991 Mini Mayfair 998Started by Eggers , 02 Jun 2022 |
