What Companies Out There Or People Make Subframes For Micra Conversion
23 replies to this topic
#16 ibrooks
ibrooks
  • 1,017 posts
Posted 16 July 2013 - 09:51 AM
But again - if the laser cutter is an in-house machine that's kept busy then the cost per job is buttons.
I've used a piece of 3mm thick tube for the front crossmember and 2mm thick tubes for the diagonals (2 each side). Mainly because they were what I had on the steel pile - doing it again I'd use something lighter for the front crossmember. My frame will be heavier than a Mini frame but not by a lot and the engine and box are a good chunk lighter. To be honest I'm kicking myself a little for not weighing the frame beforehand so that I had a comparison. I do have a near standard Auto frame that I'll try to remember to do the comparison on before I throw them into the car.
Iain
#17 666junky
666junky
  • 1,225 posts
Posted 16 August 2013 - 10:05 AM
would anyone be prepared to build me a subframe?
#18 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
  • Local Club: Weston Mini Muckers
Posted 17 August 2013 - 03:32 PM
problem with this is if someone built a frame and it broke and you crashed or killed someone it could come back to the guy who made if for man slaughter i thought about making a producing frames and to be honest its alot harder than people think the time that goes into making these subframes is a massive amount if you factor in material costs a labour all speed are very reasonable i would say they have got frames that are tried and tested looking back if i was going to build another micra mini i would save the hassle and buy a allspeed one
#19 666junky
666junky
  • 1,225 posts
Posted 17 August 2013 - 03:35 PM
They dont make a micra one though :(
#20 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 20 August 2013 - 06:34 PM
buy a suzuki one and adapt it for the micra one the frame is roughly the right shape just be a case of throwing on some engine mounts
#21 vtecmini2
vtecmini2
  • 128 posts
Posted 20 August 2013 - 07:25 PM
HI,
When making a frame to house any engine do all the big company have them test by a legal body e.g. VOSA?
or do they just test them with computer software or by actual impact testing?
thanks
#22 R1mini
R1mini
  • 1,385 posts
Posted 20 August 2013 - 08:06 PM
I bet no one has tested anything, built on the principle if looks strong enough it probably is.
The watson metro based frame will be the exception as it will be crash tested as part of the metro car crash tests
David
#23 vtecmini2
vtecmini2
  • 128 posts
Posted 20 August 2013 - 09:00 PM
thanks david I have my thoughts
john
#24 evansisgreat
evansisgreat
  • 1,095 posts
  • Local Club: Not yet
Posted 21 August 2013 - 12:46 PM
Surely if someone made a frame 'kit' that was basically missing one bit that you welded yourself they could sell without liability? Of if they sold it as a paperweight?
