Mini Getting Hot
45 replies to this topic
#16 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 20 July 2013 - 07:40 AM
Little tip for motorway driving:  Roll down hills.  Get up to speed then take it out of gear and roll down hill with the engine idling for as long as is safe and possible. Start at 70mph and when you have slowed to the point where wagons are catching you up, its time to put it back in gear and make normal progress.
Be careful doing this, make sure there is a lot of space around you. I can't say its a particularly safe thing to do but it will significantly reduce your coolant temperature.
I always do this on a long motorway journey in a mini (and other classics)
Al
Pleas do not give dangerous advice!!
http://www.highwaycode.info/rule/122
Rule 122
Coasting. This term describes a vehicle travelling in neutral or with the clutch pressed down. It can reduce driver control because
  • engine braking is eliminated
  • vehicle speed downhill will increase quickly
  • increased use of the footbrake can reduce its effectiveness
  • steering response will be affected, particularly on bends and corners
  • it may be more difficult to select the appropriate gear when needed.
#17 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 20 July 2013 - 10:22 AM
to be honest.... although there is nothing wrong with the temp on our car, I always have the heater on "hot" and when sat in traffic, I put the heater on, as this helps cooling,
I dont really need to but like Tesco's, every little helps :D
It was 32C earlier part of the week here and the car was at or just under N with the AC on....I don't have a heater, and if I had to run it under normal conditions I think I'd be doing something about it.
I had 6 week of a chinese bus driver doing that - he coast down and damned near stop going up, the select too a higher gear and then proceed to change up the box some more, just in case it did some good.
Oh, in the summer he wouldn't put the AC on...and in the winter the heater went on for 22 second at the beginning of the journey.
He was pretty much the worse driver I have every seen and I would have liked to rip the handbrake off and shove it up his armhole.
Edited by Captain Mainwaring, 20 July 2013 - 10:26 AM.
#18 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 20 July 2013 - 10:58 AM
I never said anything about coasting...........
As said, there is noting wrong with the cooling system on my car, I just like to ease the load on the cooling syaytem if sat in trafiic.....
#19 yeti21586
yeti21586
  • 3,725 posts
  • Name: Chris
  • Local Club: None
Posted 20 July 2013 - 11:03 AM
no one said you did say anything about coasting
#20 krusher74
krusher74
  • 127 posts
Posted 20 July 2013 - 12:07 PM
Yeah whats up with there driving, a taxi bemo driver I had in bali once refused to use 4th gear, drove around in rd althe time and never down shifted till he had lost all momentum!!
#21 minilee94
minilee94
  • 3,523 posts
Posted 20 July 2013 - 12:23 PM
What about changing the coolant temp switch on the head
#22 petey81
petey81
  • 1,345 posts
Posted 20 July 2013 - 12:28 PM
Al
Edited by YetI21586
wow where did you get your licence from? back of a cereal packet?
#23 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 20 July 2013 - 02:02 PM
Those Daihatsu's are becoming quite collectible now...I'm on the look out for one to put in the stable with the rest of the junk...
As for 4th gear, he probably didn't know it had one........
India and China has some **** driving, but I think we take the prize here....amazing more people aren't ground to a pulp every day......
#24 krusher74
krusher74
  • 127 posts
Posted 20 July 2013 - 03:43 PM
Oh he knew it had one, we cheered one day when he used it, but 5secs later he was back in 3rd!
#25 Badboytunes
Badboytunes
  • 1,615 posts
Posted 20 July 2013 - 04:59 PM
And your point is....................?
I was merely commenting on a post by captain manwaring.
#26 smev
smev
  • 162 posts
  • Local Club: P&S MOC
Posted 20 July 2013 - 05:10 PM
regarding the coasting, apart from being dangerous, surely it would be better to keep the revs higher so the mechanical fan is spinning faster pushing more air through :ohno: In which case the happy medium would be to go slower.
Back to the OP, I think it's down to the hot weather! I thought that electric fans were less effective at speed but my sources might have been wrong, you could try an export fan (selling one if you're interested :D) which I hear work a treat, as long as you can get clearance (does yours have a crank case breather?)
#27 1989mayfair
1989mayfair
    Starting My Mini Up
  • 4 posts
  • Local Club: MHMC
Posted 20 July 2013 - 05:38 PM
Al
Definitely the worst piece of driving advice i have seen for a long time. There is obviously something not right with your cooling system and needs to be checked out if the temp is getting way too high.
First things to check if you are sure the system is generally good and the fan is the correct way round, but still running hot is that the radiator fins are clear. The best way to do this is to remove the rad and see if you can look through it with no parts blocked and if so a good blow through with an airline is due. If and when they are clear, flush the rad and the rest of the system to make sure there is no crud in the system. Once this has been done, you may notice a big difference. If not, then it will be time to look further.
Assumptions are usually to do with the water flow, but the airflow through the rad is just as important if not more so.
Not a novice but i'm having cooling issues as well, agin the water pump is working fine and the rad is fairy new. ive just cleaned and back flushed it, the timing is good (and been checked) so is the carb setup but its still running hot. Im thinking an auxiliary fan but to be honest it should be cooling itself without the need of extra fan support.
You mention is the fan on the right way around. Mine is blowing out through the wing. On most cars the sucks the air through the radiator but this is blowing out. I think this is right but i have no way of checking. Can you please confirm that it should be pushing the air out into the wing or sucking it into the engine bay.
Thanks.
#28 Yoda
Yoda
  • 1,958 posts
Posted 21 July 2013 - 06:09 AM
If you have the standard plastic fan, the smoother side should face the engine if that makes sense! it looks wrong, which is why a lot of people install it the wrong way round to make it "look" right and yes it pushes air through the rad
#29 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 21 July 2013 - 06:46 AM
how olds your oil to look from another view? if you have cheap crap oil in surly thats causing more friction specially at speed which would warm things up a little?
#30 Tobyrm1
Tobyrm1
  • 79 posts
Posted 21 July 2013 - 07:53 AM
Changed the coolant temp switch too!
The fan on my mini is deffo the right way around blowing the air through the rad and out through the wing. The oil was changed only 3 days ago for good quality 20/50 and hasn't made any difference at all.
Thanks.
