On the front hub with disk brakes, when tightening the castle nut, first with the spacer/washer then with the conical washer I cannot get the castle nut split pin to align. The manual says tighten to the next castle nut slot, but at 200lbf torque how much more can it be tightened without my arm snapping. I tried a new conical washer, but that just made it worse, what do you guys do in this situation? File some off the castle nut?
What Should You Do With Castle Nut?
Posted 20 July 2013 - 03:30 PM
Posted 20 July 2013 - 03:33 PM
How far is the slot?
To fully tighten with holes aligned it can be somthing like 360 lbsft so eat your weetabix
Posted 20 July 2013 - 03:48 PM
Its just past so looks like I will have to buy some weetabix and a breaker bar, so just tighten till it gets there?
Posted 20 July 2013 - 03:50 PM
get a bigger bar !
Posted 20 July 2013 - 04:33 PM
Edited by Pigeonto, 20 July 2013 - 04:36 PM.
Posted 20 July 2013 - 04:39 PM
Posted 20 July 2013 - 05:39 PM
Hmmmm,
I dont like to preload the bearings too much, what I have done in the past is try a few different nuts, failing that to rub the nut and cone washer on some wet and dry on a flat surface, or if its really bad take a bit off in a lathe.
Posted 20 July 2013 - 06:42 PM
**** Likewise. Funnily enough I have just this minute completed that very job on one and ended up with a different nut to the original and also a washer, perfect! the torque wrench cracked off just as the split pin hole lined up. A washer is entirely acceptable and if you can use one made of good steel it's a better job. The bearings are pre-loaded at the torque recommended in the manual, washer or none!Hmmmm,
Posted 20 July 2013 - 09:32 PM
Read the manual...
Fit the collar and driveshaft retaining nut, and once again tighten it to the specified torque. Tighten the nut further to align the split pin holes in the driveshaft and nut, then secure the nut with a new split pin.
Posted 21 July 2013 - 03:50 PM
You sir are talking rubish, I have seen the castle nuts crack through overtightening.
Posted 21 July 2013 - 04:54 PM
Posted 21 July 2013 - 04:58 PM
If the manufacturer recommends a torque setting plus the next hole, then that is the specified torque setting. There is no argument for that.
Adding washers, or grinding the nuts down is by all accounts a bodge.
Having done probably hundereds of front bearings on vehicles of this type - Mini, Allegro, Austin 1100 and so on, this it the standard - it should be adhered to.
Listen to what the manufacturer wants, it's in writing, and correct, as per the works service manual - anything other than that could be dangerous.
Posted 21 July 2013 - 05:04 PM
Posted 22 July 2013 - 12:56 AM
Remember that there should be two split pin holes in the CV shaft, at 90 degrees, and 6 slots in the castle nut, at 60 degrees, so you don't ever need to go more than 30 degrees after reaching the minimum acceptable torque, so it should not be impossible. I have heard that some older CVs had only one split pin hole, which would make it very difficult, needing up to 60 degrees after reaching the torque.
Edited by tiger99, 22 July 2013 - 12:56 AM.
Posted 22 July 2013 - 05:49 AM
Tiger, it's the other way around, the older had 2 split pin holes and newer just 1, mine is a 96 SPi with just 1. I have only just gone past the hole so I have a long way to go. I will crank it round to next slot but first I shall try a new castle nut or 2. Jaydee says 360lbf is not unheard of but it feels it when you actually having to tighten it that tight.
