"cut and shut" tie bars
Posted 08 May 2006 - 07:03 PM
Posted 08 May 2006 - 07:08 PM
Don't be such a skinflint!
Posted 08 May 2006 - 07:10 PM
Posted 08 May 2006 - 07:13 PM
Tiebars should be fine to be "rewelded" if done absolutely correctly and evenly (There's been a few threads recently about people bending them and sending the tracking all to ) They are just mild steel bar as you say!
Posted 08 May 2006 - 07:23 PM
Posted 08 May 2006 - 07:28 PM
Posted 08 May 2006 - 07:31 PM
Posted 08 May 2006 - 07:33 PM
Posted 09 May 2006 - 06:54 AM
Posted 09 May 2006 - 12:28 PM
Posted 09 May 2006 - 12:40 PM
Posted 09 May 2006 - 01:37 PM
Be very careful...I had an adjustable 'uprated' one break once....it's not a pleasant experience!
and you drive like a girl minwah!!!!!! wasn't that due to you fitting solid bushes everywhere??????
Posted 09 May 2006 - 03:24 PM
Yeah yeah
Well I had nylon bushes...but if you ask me some of the tie rods are not very well made - there is a machined stepdown to the threads which is bound to be a weak spot. Doesn't matter how thick the rods are...it will only be as strong as it's weakest point.
I certainly wouldn't use nylon tie-bar bushes again tho, rubber & poly combo.
Posted 09 May 2006 - 04:25 PM
After watching the camber/castor/tracking being set-up on my Mini, and the amount of cross-adjustments needed, I'd think you'd be extremely lucky to, a - weld two tie bars to exactly the length needed and, b - decide what length was needed beforehand.
On mine it was a case of set the camber, get the castor something like right, then go back and adjust the camber again, then do the castor, then do the tracking, then the castor again, then camber, then the tracking, until both sides were equal and right. And you're not guaranteed to have both sides the same from the start due to irregularites in the subframe, bottom arms, top arms, ball joints etc....
