might of been covered already, sorryy.... what is the recommended battery to use on minis, i.e mini pickup running a 1293cc engine, just a radio and speakers??
What Battery Is Most Recommended For Minis
Posted 28 August 2013 - 08:53 PM
Posted 28 August 2013 - 09:04 PM
Posted 28 August 2013 - 09:08 PM
I thought 096 was the biggest you can fit in the box, I may be wrong though.
The number you want to look at when looking at batteries is CCA (Cold Cranking Amps), this is how much starting power the battery's got.
Anything designed for a diesel will be more than enough for a Mini.
Posted 28 August 2013 - 09:11 PM
All here in the FAQs Electrical section http://www.theminifo...ni-battery-box/
Posted 28 August 2013 - 09:13 PM
and what cranking amps is needed on start up on mini, or do you know what it pulls? i need to order some battery cable too but unsure what size to get
16mm2, 8.2mm OD, 110A
20mm2, 8.9mm OD, 135A
25mm2, 10.0mm OD, 170A
0mm2, 12.7mm OD, 300A
14.6mm OD, 415A
Posted 28 August 2013 - 09:15 PM
I paid about £50 for mine from a Motor Factors
Andrew
Posted 28 August 2013 - 09:18 PM
I've actually got a Ford fiesta calcium battery in my Mayfair, which isn't supposed to be at all suitable for the classic minis charging system. But it's actually bloody brilliant, it never fails, has never been near a mains battery charger and holds it's charge for months upon end when the cars not in use. I wish I could say the same for the standard classic mini battery that I've got in my other mini, but I'm afraid that's utter pants and also cost a fortune.
Posted 28 August 2013 - 09:33 PM
14.6mm OD, 415A
I believe the standard cable is 10mm OD but a bigger cable has less volt drop under load so try 12.7mm but check the sizing of your battery chanel before buying.
On a warm day and hot engine its about 120-130amps but cold wet winter mornings draw more
Posted 28 August 2013 - 09:41 PM
Type 075 is the biggest that will fit.
I've just checked and 096 will fit, however, depending on what make the battery is, you may have to file a little off the 'shoe' at the bottom in order for it to fit pass the seam inside the box.
Posted 28 August 2013 - 09:46 PM
Apparently a Bosch Silver battery is brilliant, although slightly expensive. Will be purchasing one of these very shortly.
Posted 28 August 2013 - 09:48 PM
Just depends on the battery make and the casing OD, seen one dropped in almost impossible to get out, 075 is more than any mini will ever need.
Posted 29 August 2013 - 09:09 AM
Varta blue top are good value for good price.
I wouldnt rate Bosh, seen so many bosh batteries failing in just a couple of years time that i really dont think they're worth the extra money.
Posted 29 August 2013 - 10:12 AM
- I fitted a 306 pud diesel battery. Works brilliantly. Im sure its an 086 battery. Nice snug fit with plenty of CCA.
Posted 29 August 2013 - 10:30 AM
+1 on the Bosch, Varta much better.
Posted 29 August 2013 - 10:52 AM
