Major Oil Leak
39 replies to this topic
#16 albo
albo
  • 204 posts
Posted 12 September 2013 - 01:21 PM
no mesh,,pull a rag thru with a piece of wire a few times,think petrol will expand / swell rubber
#17 2009poolesparky
2009poolesparky
  • 103 posts
Posted 12 September 2013 - 01:26 PM
ok well ill have a look and report back
#18 2009poolesparky
2009poolesparky
  • 103 posts
Posted 15 September 2013 - 01:03 PM
Cleaned it up, changed the rocker cover gasket too, went for a slow drive around town, when I came back and parked up there was some but not too much oil around the dip stick, so it confirms it was leaking out of there, and building a lot of pressure too! The oil pressure was around 70 lb/sq ft when driving around town, dropping to about 60 when idle in neutral, will have to check breathers tomorrow evening although if they are clear what else could be causing it?
#19 bmcecosse
bmcecosse
  • 9,699 posts
Posted 15 September 2013 - 02:33 PM
Oil pressure has NOTHING to do with crankcase pressure.  Test the crankcase pressure - hot engine idling, remove the oil filler cap - rev the engine.  Is there a plume of smoke/fume?  If so - the engine needs an overhaul......  As others have mentioned - check the breathers are clear, and one of them is connected to the carb to suck away any fumes.  Engine compression test will be useful - but you should have at LEAST 160 psi....   Do it with hot engine, all plugs out, and throttle held open (brick on pedal works well).
#20 2009poolesparky
2009poolesparky
  • 103 posts
Posted 15 September 2013 - 04:35 PM
ok just been over to the car and had a look in the workshop.
both breathers seem fine, they were brand new 18k miles ago, when i pulled a rag through them they were pretty clean
with the engine hot there is no pressure coming out of the oil filler hole either and no smoke either
there is no smoke coming out of the exhaust
the oil is only coming out of the dipstick hole and only out of this hole, nowhere else.
the breathers just exit with a filter on the end, they dont go back into the carbs, i have a twin su carb set up with pancake filters. no il seems to be coming out of these.
i cant do a compression test as i dont have a tool to do it with, the local garages seem pretty useless too.
#21 2009poolesparky
2009poolesparky
  • 103 posts
Posted 15 September 2013 - 05:49 PM
having a read its suggesting piston rings, but then surly if it was them id see burning oil out of the exhaust too?
#22 tiger99
tiger99
  • 8,584 posts
Posted 15 September 2013 - 06:14 PM
Yes, probably you would have a smoky exhaust. It is very odd that it is coming out of the dipstick hole without there being excess pressure in the rocker cover. Worth checking the spark plugs to see if they are oily.
I think that the next step should be to check that your breather system is assembled correctly. The Somerford Mini web site will show you diagrams of what bits should and should not be fitted.
#23 2009poolesparky
2009poolesparky
  • 103 posts
Posted 15 September 2013 - 07:01 PM
ok thanks for your help, need to fix this asap as it is essentially stopping me driving the car anywhere around town let alone on the motorway :/
#24 2009poolesparky
2009poolesparky
  • 103 posts
Posted 16 September 2013 - 06:57 PM
Ran her up tonight checked the breathers again and they were fine, no oil in exhaust and no pressure at oil filler cap, some slight pressure at both breathers but nothing I would consider obviously too much, when revving in idle still leaking out of dip stick :( help? Can't do compression test yet as don't have a tool
#25 2009poolesparky
2009poolesparky
  • 103 posts
Posted 16 September 2013 - 06:58 PM
Spark plugs are also clean
#26 Carlos W
Carlos W
  • 10,114 posts
Posted 16 September 2013 - 07:01 PM
Is there any chance you could've overfilled it?
Are you checking it on level ground?
Other than that, a faulty pressure relief valve maybe?
#27 Spitz
Spitz
  • 1,716 posts
Posted 16 September 2013 - 07:40 PM
Can you pull those filters off the breathers and see if things change....  60lb at idle when engine is warm?...seems awfully high
#28 2009poolesparky
2009poolesparky
  • 103 posts
Posted 17 September 2013 - 05:06 AM
Yes I ran it with the breathers off altogether, on level ground and the oil is about halfway on the scale, where abouts is the pressure relief valve and how do I know if it's set correctly, seems strange, I've only had the car a few weeks and drove it back from York to reading and was using it for about a week before it started happening
#29 Spitz
Spitz
  • 1,716 posts
Posted 17 September 2013 - 03:03 PM
Pic is an auto...but same location
#30 Cooperman
  • 23,326 posts
Posted 17 September 2013 - 03:12 PM
As 'bmc....' says, the oil pressure has nothing to do with crankcase pressure, so forget that as it's not an issue.
