Engine Troubles.. Help :( What Is This Engine
Posted 15 September 2013 - 01:55 PM
I think it may be a mg metro engine but I ain't sure
thanks in advance
Posted 15 September 2013 - 02:04 PM
These are normal A+ sintered rockers, your carb has a crappy dashpot damper fitted to 'economy models', you want the LZX2085.
For the rest, with no engine number, the only way to tell if its an MG metro engine is to take engine apart.
Posted 15 September 2013 - 02:09 PM
http://www.minispare...rs/LZX2085.aspx
like this??
Posted 15 September 2013 - 02:13 PM
You say 'engine troubles' - then you don't tell us what the 'trouble' is?
Yes, thats the one!
Posted 15 September 2013 - 02:17 PM
Yes, thats the one!
I'll get one ordered
the trouble I don't know what engine this :/You say 'engine troubles' - then you don't tell us what the 'trouble' is?
Mini Technical Sections →
Problems, Questions and Technical →
Crank Damper For Ribbed Belt PulleyStarted by BaronVonchesto , 01 May 2024 engine |
Tapping Noise At IdleStarted by Sterling M , 27 Apr 2024 engine |
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
