Hi guys
I have a problem with my wheel and break set up at the moment, my 10" dunlop d1's don't fit over them and I can't put any spacers on them because when I put it on full lock it hits as I haven't widened out the arches
I have been suggested to go to a cooper s set up but it's proving quite costly and I don't want to go to 12" as it compromises my performance, any suggestions on what to do and has anyone come across this problem before?
2 replies to this topic
Posted 21 September 2013 - 06:09 PM
Posted 21 September 2013 - 06:17 PM
I have mini speed 4 pot callipers and 7.9" vented disks
Also how does the performance of the cooper s setup compare to the mini speed one?
Posted 21 September 2013 - 07:52 PM
You can't just fit spacers as a magic cure for clearance problems, as they spoil the suspension geometry, particularly the scrub radius, which really can ruin the handling, as well as overstressing the wheel bearings. Spacers have to be chosen in conjunction with wheel offset, and should never be necessary if the wheel is for a Mini.
You may sometimes get away with spacers at the back, as they don't impair the handling, but the wheel bearing problem remains.
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Adjusting Brake Bias For 7.5" Discs With Pdwa ValveStarted by Daniel Watkin , 16 Nov 2023 brakes |
Answered
Fam7821 Brake Limiter Valve - Mounted Upside Down?Started by tarnofsky , 29 Sep 2023 brakes |
Kent 286 Can & MotStarted by frosty90 , 07 Sep 2023 brakes |
Brake Master Cylinder ReplacementStarted by M I N I , 30 Aug 2023 brakes |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
