Hey everyone, I got an issue with the rear brakes on my 1990 Mini City hoping you may be able to point me in the right direction. I have replaced the shoes, wheel cylinders and bled the lines. When I raise the car, give the rear wheels a spin and press on the brake pedal the brakes will engage and stop the wheel however they release immediately after and the wheel rolls freely. I have pulled the drum to get a closer look and I can see the shoes expand but then compress immediately after. The parking brake works fine and the shoes have been adjusted so they are just barely backed off the drum. The front brakes (disc) work fine. There are no leaks from what I can see in the system. I have a 'type 4", tandem master cylinder (green tag). I did some more digging online but did not see any posts on this type of issue. Only thing I can think of is that it's an issue with the seals in the master cylinder which is causing the rear line not to hold it's pressure. Again, front brakes lock up tight when tested. Any direction on this is greatly appreciated as I want to get this thing cruising down the road before winter sets in! Thanks.
2 replies to this topic
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Adjusting Brake Bias For 7.5" Discs With Pdwa ValveStarted by Daniel Watkin , 16 Nov 2023 brakes |
Answered
Fam7821 Brake Limiter Valve - Mounted Upside Down?Started by tarnofsky , 29 Sep 2023 brakes |
Kent 286 Can & MotStarted by frosty90 , 07 Sep 2023 brakes |
Brake Master Cylinder ReplacementStarted by M I N I , 30 Aug 2023 brakes |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
