My First Mini Project On A 1979 Clubman
clubman
52 replies to this topic
#1 iToNiiCz
iToNiiCz
  • 683 posts
Posted 30 September 2013 - 06:54 PM
hi All well here is the first of many pictures of my clubman 1979.
started by try to see where the rust is and what panel i might need to get
Edited by iToNiiCz, 05 December 2013 - 10:55 AM.
#2 littlemissmagic
littlemissmagic
  • 514 posts
Posted 30 September 2013 - 07:14 PM
I also have a 1979 clubman project so I will be watching this :)
I've had mine 2 years and I still haven't started working on it properly!
Best of luck with it :)
#3 iToNiiCz
iToNiiCz
  • 683 posts
Posted 02 October 2013 - 12:31 PM
i have now cut out all the rusty bits ready to weld the new panels in
these are the patrs i got
front floor
inner sill
outer sill
froni floor well
door step
FRONT/REAR FLOOR & JP.TO 1st GROOVE SALOON 6 FLUTE RH
do you guys think this is  all the stuff i need  ,and what should i weld first?
Edited by iToNiiCz, 02 October 2013 - 01:37 PM.
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 02 October 2013 - 04:45 PM
I would get that braced so there is less chance of movement. weld a bar across the door frame.
You say you have front floor, front floor well and front/rear floor which are you planning on using.  I'm not to sure what you should weld in first, But I would have cut out less and just replace a panel at a time if possible.
#5 rally515
rally515
  • 3,848 posts
Posted 02 October 2013 - 04:49 PM
Refer to the other doorstep for measurement then weld in the new doorsep first and then make your way round as you please whilst checking back that the door frame is still straight and the correct measurements from the other side, also measure from inner sill to inner sill so you dont get that alingnment wrong, that should be 160.7 mm or there abouts
#6 alex-95
alex-95
  • 6,078 posts
Posted 02 October 2013 - 04:55 PM
And don't forget to refit the door to check the fitment, before you've fully welded it in, there may be a large gap at the bottom.
#7 rally515
rally515
  • 3,848 posts
Posted 02 October 2013 - 04:57 PM
Ahh yeah and do that aswell :lol:
#8 minimikej
minimikej
  • 355 posts
Posted 03 October 2013 - 11:54 AM
Ye gods, that's a mess!
I'd advise stop chopping and start adding. You can tack weld just for now if you know what you're welding to is to be chopped out later if that makes sense.
Good luck :)
#9 SAL 821X
SAL 821X
  • 1,891 posts
Posted 03 October 2013 - 12:26 PM
Crikey "Bull in a china shop" springs to mind. Certainly can't fault you for getting stuck in.
When you say "these are the patrs i got"
front floor
inner sill
outer sill
froni floor well
door step
Do you mean that you have bought all these panels as essentially the 3 in bold are the same?
As other have said I'd brace the door pillars as you've cut a fair amount out there a bit soon.
#10 SAL 821X
SAL 821X
  • 1,891 posts
Posted 03 October 2013 - 12:35 PM
Other than that I'd probably measure up and fit the door step first to get some strength back, then move on to the footwell, inner sill and finally the outer sill.
But that's just my inexperienced opinion.
#11 iToNiiCz
iToNiiCz
  • 683 posts
Posted 03 October 2013 - 04:35 PM
hi yeh i got all those in bold so are they the same part
#12 alex-95
alex-95
  • 6,078 posts
Posted 03 October 2013 - 04:41 PM
It seems like they are.
#13 SAL 821X
SAL 821X
  • 1,891 posts
Posted 03 October 2013 - 06:54 PM
Well same part is perhaps the wrong term.
They do cover the the same areas I meant.
#14 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 04 October 2013 - 06:05 AM
good luck matey!
#15 SAL 821X
SAL 821X
  • 1,891 posts
Posted 04 October 2013 - 06:19 AM
Itoniicz grab a picture of the panels you have and post it up then we can see whats what.
Also tagged with one or more of these keywords: clubman
