Photos are on their way.
If you are fitting 10" wheels, even reverse rim, it is unlikely that they will fit over anything larger than the 7.5" Cooper 'S' set-up which was what the 'works' used. You cannot simply use spacers as that is quite dangerous.
The seats used on 'works' rally Minis varied over the years. The driver's seat was normally low-back and the navigator's would have had a head rest on longer events to allow one crew member to get some sleep on road sections.
The 'works' cars had very different specifications from year to year & event to event. That's why Peter Browning's book 'The Works Minis' is so good. For example, on the 1966 Monte Carlo, the cars ran in Group 1, so they had standard seats with special seat covers, 3.5" x 10" wheels, helical gear-boxes, 2 spotlights (actually fog lights), single 5.5 gallon fuel tank. That can be compared to the group 2 cars which had 4.5" or 5" wide wheels, twin 5.5 gallon tanks, straight cut close ratio gearboxes, 4 or 5 additional spot/fog lights, perspex windows, twin 1.5" SU carbs (or even twin split Webers).
Early cars had no roll cages, but later ones had a single roll-hoop with a back stay to the rear parcel shelf. Some had swivel roof-lights which could be operated by the co-driver on special stages, but others did not.
There are so many variations.
