Posted 30 October 2013 - 06:21 PM
But my problem ( if u guys can help) is with the knocking at the front of the car. Every time I drive the car abit or go down hill I hear a knocking in the front of the car. I have had this previously before on the car but got all my front-end re-done, new ball joints both sides, new bearings, new cv joint on driver side and New gators. Previously it was the Bearing on the passenger side which failed and I had a new flange and stress washer put on. But after all this there still is a very loud knocking, can any of u help.
Many thank Leanne.
Posted 30 October 2013 - 07:27 PM
Without seeing and driving the car it is very difficult to do any sort of diagnosis.
Posted 30 October 2013 - 07:29 PM
Posted 30 October 2013 - 07:33 PM
Posted 30 October 2013 - 07:39 PM
hard to tell could be number of things.
1) When stationary in neutral and rev the engine does the front end move, if so may be engine steady top or bottom.
2) Could be one of the subframe mounts.
3) suspension mounts perhaps?
Posted 31 October 2013 - 10:24 AM
In short, check the tower tops on the subframe.
Edited by dp0352, 31 October 2013 - 10:25 AM.
Posted 31 October 2013 - 10:50 AM
engine steady seems a good place start considering 2nd reply they mention hometune guy had said a bush was missing.
is it a knock knock knock or just a knock when you go on and off the accelarator
Posted 31 October 2013 - 04:45 PM
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
