Posted 22 May 2006 - 02:31 PM
Having used 'em all over the years, here's my personal opinion on the ones availble today:
Falken - good all rounder, surprisingly good in the dry, and if you dont drive like a tit in the wet, are more than up to the job. Wear rate similar to A008's
Yoko A008 - another good all rounder, but dont get over confident - has plenty of grip, then just lets go suddenly. OK in the wet round corners taken sensibly. Fronts on mine wear out at about 10k miles.
Yoko A032R - very good in the dry, OK in the wet, but wear quickly. 5k miles on the fronts and thats with taking it easy most of the time.
Camac - useful allrounder, cheap and cheerful. Not up to the Yoko's standard in the dry, but I found equally as grippy in the wet. Seemed to wear faster than the A008's though.
I'm still running A008's and not had a problem with supply - the pair I bought last month were manufactured in December 2005, so I suspect they are still in production.
Supplier wise, I normally get them from the mini shows or from www.mytyres.co.uk - I'm lucky enough to have free fitting facilities, but most independant fast fit places will fit 'em cheaply.
