Bmc 1500 Diesel In Mini?
29 replies to this topic
#16 surfblue
surfblue
  • 1,827 posts
Posted 15 November 2013 - 09:03 PM
There a guy in Northern Ireland has a Peugeot 1.4 d in a clubman, needed the front wings lengthened slightly. I'm another big diesel fan, loads of torque and excellent fuel economy, what's not to like?
#17 Carlos W
Carlos W
  • 10,114 posts
Posted 15 November 2013 - 09:19 PM
It depends on the engine!
#18 surfblue
surfblue
  • 1,827 posts
Posted 16 November 2013 - 09:14 AM
VW's TDIs are superb. One of those in a mini would be quite a machine, has anybody managed to do that?
#19 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 16 November 2013 - 12:14 PM
Have you seen the size of them though? They are great engines but I can't see how you would get it under a Mini bonnet.
#20 Carlos W
Carlos W
  • 10,114 posts
Posted 16 November 2013 - 12:15 PM
My wifes Ibiza FR only just had enough room for the engine, changing headlight bulbs on one side was much easier if you removed the battery!
#21 jmmini
jmmini
  • 711 posts
Posted 16 November 2013 - 01:23 PM
Do zcars not do one? Or is that just the grasstrack cars?
#22 surfblue
surfblue
  • 1,827 posts
Posted 16 November 2013 - 06:18 PM
Was thinking of the 3 cylinder from the Polo rather than a 4 pot!
#23 mini13
mini13
  • 3,811 posts
Posted 16 November 2013 - 06:21 PM
still a big lump, same as the 4 cyl but with 1 cyl less.
#24 mab01uk
mab01uk
  • 12,571 posts
Posted 16 November 2013 - 08:11 PM
Perhaps BMW's new 1.5-litre, three-cylinder turbocharged engine for the F56 MINI will be compact enough to fit under the bonnet of a classic Mini in the future.........?
Codenamed B38 (petrol) and B37 (diesel), it will come in petrol and diesel forms and is expected to be between five and 15 per cent more economical than BMW’s current N20 four-cylinder engines. Built on an alloy block, the engine gets Valvetronic variable valve timing, a single turbo, 11.0:1 compression ratio. It has been engineered as part of BMW future modular engine strategy, which sees all engines based on the same individual 500cc cylinder.
The B37 diesel engine shares up to 60 per cent of its architecture with the B38 petrol engine and can be made on the same production line. The diesel engine output will range between 100bhp and 181bhp and 166lb ft and 221lb ft of torque.
A balance shaft, that is built in the engine’s crank case evens out the vibrations that you would typically expect in a 3-cylinder.
The first test drive with the F56 3-cylinder New MINI's next week should provide a little confidence to people who are still critical when hearing the word 3-cylinder.
http://www.autocar.c...engine-revealed
Edited by mab01uk, 16 November 2013 - 08:14 PM.
#25 surfblue
surfblue
  • 1,827 posts
Posted 17 November 2013 - 12:20 AM
A modern, low maintenance tdi with a high torque / low fuel consumption engine in the classic bodyshell would make for a very desirable mini indeed.
#26 Mini Mad Drakeley
Mini Mad Drakeley
  • 1,172 posts
Posted 17 November 2013 - 12:58 AM
ive actually been thinking about this kind of thing for a while as my boss told me about an engine from some car made in japan or korea, its a 1lt 3 cylinder turbo diesel with 150bhp and its made from aluminium so its small and light. ive been debating getting one of those and doing an engine conversion, need to find out what the engine is from again though and see if i can pick one up cheap.
Adam
#27 mab01uk
mab01uk
  • 12,571 posts
Posted 17 November 2013 - 10:40 AM
A modern compact tdi engine in a classic Mini bodyshell which weighs a fraction of most modern small cars should give impressive mpg figures!
Classic Mini - Kerb Weight = 640 kg (1,411 lbs)
BMW MINI - Kerb weight = 1,215 kg. (2,678 lbs )
#28 mini13
mini13
  • 3,811 posts
Posted 17 November 2013 - 11:15 AM
MPG isnt all about weight, remember the mini has a  pretty bad aerodynamic coeficient, 0.48 for a mini, 0.35 for a BINI.
#29 lsto
lsto
  • 610 posts
Posted 17 November 2013 - 12:17 PM
I seem to remember reading something like this in I thing practical classic or some magazine my uncle give me a few years ago, the fella fitted a diesel into a midget and seemed to work fine, a mini would be an interesting concept...
As for diesels, I love 'em, my old astra van has just gone past 245500 miles and still going strong. Love it ;D
#30 HarrysMini
HarrysMini
  • 3,352 posts
Posted 17 November 2013 - 04:28 PM
Although it's a pretty big part of it!
