5 replies to this topic
Posted 19 November 2013 - 01:44 PM
Ok so, just done a gearbox rebuild and as I was taking he engine out we ended up taking the brake master cylinder diaphragm thing off (the front part of the cylinder).
Put it all back together and bleed the brakes now there's no pressure at all and the brakes only work once pumped a lot.
Any chance I've damaged the diaphragm?
Thanks.
Thanks.
Posted 19 November 2013 - 01:46 PM
Once you've pumped them a lot, do they continue to work normally?
Posted 19 November 2013 - 02:22 PM
No, if the engine isn't running then they don't even pump hard
Posted 19 November 2013 - 02:26 PM
Sounds like it's still got air somewhere in the system - did you bleed it with an easy bleed or just with a jar? The reason I think it's got air is that pumping it squishes up the air and gives you some resistance, but when you stop it all expands again and goes soft.
I always had problems using the jar and pump method, the easy bleed made things really simple.
Posted 19 November 2013 - 02:40 PM
Used an easy bleed kit which holds the pressure in the system by using the air in the wheel.
Wondering if I've damaged the seal in the servo?
Posted 19 November 2013 - 02:58 PM
I would try bleeding it again, sounds like air in the system to me.
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Adjusting Brake Bias For 7.5" Discs With Pdwa ValveStarted by Daniel Watkin , 16 Nov 2023 brakes |
Answered
Fam7821 Brake Limiter Valve - Mounted Upside Down?Started by tarnofsky , 29 Sep 2023 brakes |
Kent 286 Can & MotStarted by frosty90 , 07 Sep 2023 brakes |
Brake Master Cylinder ReplacementStarted by M I N I , 30 Aug 2023 brakes |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
