orange light on dash
dan_g
, May 23 2006 04:19 PM
29 replies to this topic
#16
Posted 23 May 2006 - 06:41 PM
thats what i'd go with. big job to replace from what i've read too.
also if the car dies when you open the oil cap then its weak not rich. there is a pipe on the carb connected to the crank case. the oil filler cap is a filter so it lets air in. the gases go round the engine then into the car thro a breather pipe. if the car stalls with the cap off then too much air is getting to the carb. with a high air mix then the car stalls.
#17
Posted 23 May 2006 - 06:49 PM
as the light goes off at higher revs is it safe to say that the pump is probably up the duff ?
Either that or the oil pressure releif valve is stuck or the engine is generally worn. It could be that the pressure sender switch is broken but if that happened it would more than likely just stay on all the time. Given the previous owner's attitude to maintenance I would guess at worn bearings but that still means engine out the same as a new oil pump does. Try cleaning and reseating the pressure valve just in case it is that but it's not likely.
Edited by Dan, 23 May 2006 - 06:51 PM.
#18
Posted 23 May 2006 - 07:08 PM
can i replace the pump without taking the engine out ?? (i cant find my haynes atm so im unsure of the process)
#19
Posted 23 May 2006 - 07:19 PM
you have to take the clutch off, so not really...
check the relief valve first. much easier.....
#20
Posted 23 May 2006 - 07:22 PM
ok, thanks alot ..... how will i go about doing this ?
#21
Posted 23 May 2006 - 07:23 PM
taking the engine out.....errmm.....unblot eveything and watch it fall.
#22
Posted 23 May 2006 - 07:26 PM
lol......... i meant checking the relief valve
#23
Posted 23 May 2006 - 07:31 PM
its a big "bolt" at the front of the engine, just by where the sensor and the oil-tube is on the LH (as you look at it) side. take it out, check the spring, in fact replace the spring and the cup thats in there, and give it a go.
#24
Posted 23 May 2006 - 07:33 PM
thanks alot for your help ..... i will give it a go 2 moz when it is lighter
#25
Posted 23 May 2006 - 08:32 PM
d'oh sorry.
#26
Posted 23 May 2006 - 09:21 PM
If the relief valve is sticking then you could replace it with the ball and spring one from minispares.com
Oil release valve kit. Part no. AEA536KIT
As fitted to the original cooper S and also helps the engine run smoother.
Also if the current pressure relief valve spring is shorter than 73mm then its only fit for the bin.
While you’re at it replace the oil switch, just to be on the safe side.
Part No. GPS133
Part No. GPS133
#27
Posted 23 May 2006 - 09:45 PM
Am i right in saying though, that the oil pressure relief valve doesn't affect the oil pressure whilst the engine is running at idling speed, only when you rev the engine does the oil pressure relief valve do anything.... Just what i remember reading somewhere...
#28
Posted 23 May 2006 - 09:53 PM
But if the pressure relief valve is stuck open then it will allow the oil to flow back in to the sump bypassing the engine, giving low oil pressure at idle.
The reason why they are fitted is when the oil pressure is too high, it opens and allows some of the oil to flow back in to the sump reducing the oil pressure to a more reasonable amount.
too much oil pressure can be just as bad as too little oil pressure.
#29
Posted 23 May 2006 - 09:56 PM
and also why the light goes out at higher revs when its "supposed" to be open.
#30
Posted 23 May 2006 - 10:09 PM
At higher rpm the oil pump is working harder meaning it is producing higher oil pressure; some of witch is not needed so the relief valve opens to reduce it.
The pressure relief valve is NOT open all the time.
