Fiat Punto 1.2 16V Conversion......... Time To Get It Finished!
27 replies to this topic
#16 Biggelmo
Biggelmo
  • 29 posts
  • Local Club: Eastbourne & Distric
Posted 03 January 2014 - 09:41 PM
Another Fiat powered Mini, I started my own Punto engine conversion about 2 years ago but I went for an 8v Punto 75 engine and 5 speed box.
The 8v P75 is only 5bhp short of the 16v but because its a single cam means I can retrofit an Uno distributor,my original plan was to use 32mm motorbike carbs but making an inlet manifold was a right pain so I may go to plan B and modify the standard P75 inlet manifold to take some type of Weber twin choke.
Here's a link to some pics of mine.....
http://www.16vminicl...ead.php?t=29435
Good luck with you build.
#17 woody78
woody78
  • 113 posts
Posted 03 January 2014 - 11:12 PM
Thanks bud, good luck with yours too. Just had a flick through your thread and really like the look of your subframe. Given me a few ideas for when I re-do mine. I think my whole engine is slightly further forward than yours as there was no way the driveshafts would have gone through the original holes and the gearbox clashed on the front of the frame too!
#18 woody78
woody78
  • 113 posts
Posted 04 January 2014 - 08:37 PM
Went up the workshop again today and made a list of panels I need to get ordered and roughly how much sheet steel I'm going to need.
Also got the KA dash stripped and had a look at how I'm going to get it to fit.
Attached File  image.jpg   68.07K   34 downloads
Got loads of photos of other peoples that have been fitted and there's little bits from each I like.
Attached File  image.jpg   81.31K   38 downloads
Think this one looks really good painted
Attached File  image.jpg   144.99K   44 downloads
But like the flocked look too
Attached File  image.jpg   57.26K   48 downloads
I'm going to cut mine the same as this one as would like to keep the vents at both ends
Attached File  image.jpg   41.21K   30 downloads
Also going to try and keep the original mini heater and modify the panel in the KA dash for the on/off switch and adjuster from the mini one
Been speaking to someone breaking a Punto about cutting out the floor out where the gear stick mounts to. Would like to weld the whole thing into the mini floor as at the moment the Punto gear stick I have is trimmed down to fit in the mini tunnel and isn't as stable as I'd like. May also move it backwards slightly to make more room for the gear stick with the KA dash.
Attached File  image.jpg   75.41K   8 downloads
That will probably mean that the handbrake will then need moving back slightly too but as it's had a dodgy repair in the past I'll be making new brackets for that anyway
Attached File  image.jpg   62.88K   3 downloads
Other than that just got the old sound proofing up from the rear floor to see what condition it was in underneath. All looks pretty good really
Attached File  image.jpg   85.15K   4 downloads
Anyone know where I can buy these metal blanks for the floor? A couple are a bit bent up in the rear and the ones in the front foot wells will get replaced too
Attached File  image.jpg   76.96K   5 downloads
Edited by woody78, 04 January 2014 - 08:39 PM.
#19 Biggelmo
Biggelmo
  • 29 posts
Posted 04 January 2014 - 10:58 PM
Hi again,on the subject of gear levers/changers I did buy a Mk1 Punto cable set up but the cables looked to be a bit long, so I was going to try and look at a Panda or Uno set up to see if they were any shorter.
Also check out the EPER Fiat parts catalogue on the Fiat Forum http://eper.fiatforum.com
#20 woody78
woody78
  • 113 posts
Posted 09 January 2014 - 06:20 PM
Was at the workshop Tuesday evening. Started with a lot of poking about to find more rusty bits and found a couple more. Waiting till the end of the month though to get all the panels and sheet metal I need ordered in one go.
So then I started having a look at the KA dash again. I got a photo of the rear of the dash today to show the steel bar that runs through it.
Attached File  image.jpg   78.26K   10 downloads
I'll be cutting out the mini's lower dash rail and using the KA's rail so that I can utilise as many of the dash components as possible. Otherwise a lot of the glove box is lost due to it clashing with the lower rail
So after taking a load of measurements this happened...
Attached File  image.jpg   74.74K   15 downloads
Having the two halves meant I could trim each end into the mini quite easily, then with them overlapping in the middle with a few clamps and a load of cable ties I could see it taking shape
Attached File  image.jpg   74.04K   39 downloads
There is hardly any room between the dash and where the gear stick mounts so this is why I will be moving the section of the floor backwards. I'll probably also move the crossbeam and handbrake backwards too to maintain a good driving position
Attached File  image.jpg   73.81K   19 downloads
And there's even less room with this lower part of the dash fitted but I definitely want to keep this section
Attached File  image.jpg   70.21K   11 downloads
It looks like in going to be able to use the mini's heater too and just make up a new face plate to fit the KA dash
Attached File  image.jpg   59.53K   14 downloads
So last thing I did was strip the Corsa power steering column down to the bare minimum of what I need on it and size it up. Looks like this will fit fine under the dash too :)
Attached File  image.jpg   77.85K   5 downloads
#21 MrBounce
MrBounce
  • 2,658 posts
Posted 09 January 2014 - 10:02 PM
I really like this. Good work! :thumbsup:
#22 Dusky
Dusky
  • 5,322 posts
Posted 10 January 2014 - 06:39 AM
Nice! We had a punto,never knew this would work :D
#23 woody78
woody78
  • 113 posts
Posted 11 January 2014 - 07:50 PM
Cheers for the comments guys :-)
I got this frame from work as it was gunna be scrapped. Figured I'd be able to use it for making my subframe jig
Attached File  image.jpg   59.02K   6 downloads
Little bit overkill but I'll chop it down.....
Attached File  image.jpg   58.45K   1 downloads
So here's where I got to today. Made the top mounts which unbolt for ease of getting it in and out
Attached File  image.jpg   74.73K   11 downloads
Then chopped it ready to make it shorter and then I'll start with the front section
#24 h4wx1e
h4wx1e
  • 553 posts
  • Local Club: sutton mini club
Posted 12 January 2014 - 05:43 AM
Nice project their, I put a ka dash in mine years ago if you need anymore inspiration or ideas click my signature below or visit Sutton Coldfield classic mini club and search for me under the same name as this one and have a look at the pics theirs quite a lot which might help, but as I kept the a series their was a lot more messing with the dash to overcome all the problems you mentioned. Good luck with project
#25 woody78
woody78
  • 113 posts
Posted 12 January 2014 - 02:35 PM
Thanks bud :-) I'll take a look
#26 woody78
woody78
  • 113 posts
Posted 13 January 2014 - 06:32 PM
Just ordered a load of panels and repair sections up so hopefully get started with the body this week or early next week :-)
#27 woody78
woody78
  • 113 posts
Posted 19 January 2014 - 03:35 PM
Panels turned up this week :) outer sills, rear valance, valance close outs, heel board repair sections, rear quarter repair section and floor pans. So that's enough to keep me going for now.
Except I'll be returning the sills as they turned up like this.....
Attached File  image.jpg   66.84K   11 downloads
Attached File  image.jpg   66.16K   9 downloads
Anyway Wednesday night I did some more trimming on the dash and held it together with some 1"x2" aluminium plates that will be riveted with countersunk rivets and filled over once finished but for now they're just held in with self tappers
Attached File  image.jpg   69.24K   21 downloads
So today I got the metal support bar that goes behind the dash cut down to shape and welded up so next job is to make the mounts for each end and weld them in
Attached File  image.jpg   71.02K   14 downloads
Attached File  image.jpg   73.65K   14 downloads
Attached File  image.jpg   30.98K   11 downloads
Attached File  image.jpg   51.4K   9 downloads
Attached File  image.jpg   58.95K   20 downloads
So once I've made these up I'll look at moving the gear stick mounting point backward before moving onto the rest of the floor.
#28 woody78
woody78
  • 113 posts
Posted 07 February 2014 - 03:21 PM
Haven't had much to report the last few weeks as I've mainly been trimming and fettling the dash. But now it's in and mounted :-)
Attached File  image.jpg   70K   12 downloads
I made the mounts on each side and then cleaned up all the edges except the top as I don't have a compressor yet and need the die grinder to get in there!
Attached File  image.jpg   61.83K   13 downloads
Attached File  image.jpg   59.81K   7 downloads
You can barely see these when the dash is mounted and shouldn't notice them at all once they're painted properly along with the interior
Attached File  image.jpg   53.89K   11 downloads
So here's a few photos of the support in place. From this I'll mount te heater matrix and possibly steering column support, but unsure now whether to use the power steering column from the Corsa....
Attached File  image.jpg   76.85K   14 downloads
Attached File  image.jpg   72.62K   11 downloads
Attached File  image.jpg   66.41K   11 downloads
I put a few of the trim pieces in to get a better view of how it will look when finished. I still need to sand it all back and fibreglass and fill bits but I'll do that once I've started that stage with the shell
Attached File  image.jpg   71.23K   32 downloads
So the next task is to start welding the floors and to sort this problem....
Attached File  image.jpg   64.43K   19 downloads
I need to move the mounting point for the gear stick backwards quite a bit. I think I'm going to go for MG ZR seats so I need to start measuring up to make sure wherever it's mounted is still comfortable
Edited by woody78, 07 February 2014 - 04:03 PM.
