Best Place For Intercooler
Posted 20 December 2013 - 11:34 PM
Was thinking just putting a small one where the dizzy is,
Or then a big exposed one the full width of the car under the bumper, what's the chances of damage when doing this?
Posted 20 December 2013 - 11:40 PM
small and efficient would get my vote. Just remember to make sure it has flow out of the back of it too
Posted 20 December 2013 - 11:43 PM
Just push it as far forward towards the grill? Obviously I'm not going to make loads of room between the cooler and the block though?
Posted 20 December 2013 - 11:50 PM
You may be able to mount one behind the valance with some holes cut into it, otherwise mounting it behind the slam panel with some holes in the bonnet,
thats what I would do personally
Posted 20 December 2013 - 11:53 PM
Could get one which goes from the top of the bonnet down to the valance with holes in it too,
Next time I see the mini I'll have a good look :)
Obv the valance doesn't have any structure properties so I can drill as much as I want?
Posted 20 December 2013 - 11:56 PM
I cant see why not but the subframe sits right behind so you may not have enough space, but mounting one to the subframe hanging down with some airflow to it through the valance might work (or if you fancied a bodykit the zeemax would go some way to giving you somewhere to mount it without it being exposed )
Posted 20 December 2013 - 11:59 PM
Body kits are gayyy
Also if I did mount one by the valance and make a e type jag type of scoop,
Like I said will have a good look next time I see the mini
Posted 21 December 2013 - 09:57 AM
Posted 21 December 2013 - 10:20 AM
http://turbo-mini.com/9629/index.html I managed to fit this in with a little work.
Phil.
Posted 21 December 2013 - 12:53 PM
Phil.
What doesn't it look like with the grill on?
Posted 21 December 2013 - 03:03 PM
Posted 21 December 2013 - 07:33 PM
Phil.
Posted 22 December 2013 - 01:46 PM
Std rs turbo cooler
Fits nice and easy
Edited by mossy2a, 22 December 2013 - 01:48 PM.
Posted 22 December 2013 - 02:15 PM
