Light Fault
electrical
26 replies to this topic
#1 The Joker
The Joker
  • 113 posts
Posted 27 December 2013 - 10:28 PM
Hi there! I'm relatively new to Minis (or cars in general) and I've just discovered my front lights don't work. I think it's something to do with the switch because the lights work if I pull the indicator stalk back to 'flash' someone but not when I push the stalk forward.. Also the fog light doesn't work as it would only work when the lights are on full beam. Would a broken fuse be responsible for this?
Edited by The Joker, 27 December 2013 - 11:35 PM.
#2 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 27 December 2013 - 11:06 PM
check the fuses along the front scuttle and if you have the 4 fuses check the bottom one. If they haven't blow then check the connections it might be a dodge earth or something along them lines or a short circuit if not then change the switch they arent that much from minispares and if you get TMF+ then you get some money off as well :)
#3 jaydee
jaydee
  • 8,565 posts
Posted 27 December 2013 - 11:08 PM
Main beam its not fused
Flashers should use a relay feeded by the rocker switch
but i'd still investigate the switch first
#4 The Joker
The Joker
  • 113 posts
Posted 27 December 2013 - 11:20 PM
Right okay thanks guys! :)
#5 corrado vr6
corrado vr6
  • 678 posts
Posted 28 December 2013 - 01:44 AM
I would be checking the connections under the front slam panel, so where the bonnet pin goes, there is a whole bundle of them, pull them apart clean and put back
#6 welldc
welldc
  • 92 posts
  • Local Club: Robin Hood Mini Club
Posted 28 December 2013 - 09:53 AM
Had the same problem and found a bunch of in line fuses under the dash, above the steering column.
One of them was brown and shaped like a banana, obviously been hot. Strangely, the fuse looked ok.
Replaced the inline fuse holder and put in a new fuse. Got headlights back.
Even though the glass fuse looked OK, when tested, it was a dud.
#7 tiger99
tiger99
  • 8,584 posts
Posted 28 December 2013 - 03:00 PM
There is NEVER one single fuse that would take out both headlights. It is illegal and dangerous. What sadly is legal, but dangerous, is the way that both headlights are earthed back to the bulkhead by a single black wire, which usually fails due to corrosion at the bullet connectors already mentioned. For safety's sake, you should add a seperate earth for each headlight.
However, if the flasher works and the lights do not work from the switch, the earth is intact, and the problem is the light switch, or the blue wire between there and the dip switch.
#8 The Joker
The Joker
  • 113 posts
Posted 28 December 2013 - 05:55 PM
I replaced the switch and checked the 4 fuses on the scuttle panel and they seem to be ok too but still the same problem exists :/ welldc, did you say there are fuses just above the steering column behind the dash?
#9 CityEPete
CityEPete
  • 3,920 posts
Posted 28 December 2013 - 06:17 PM
I have been doing work in this area just today so its quite fresh, what year car is this for a start?
fuse 7-8, the bottom one only gets power when the lighting switch is operated so first question, do you have sidelights all round and the instrument cluster on? if so then you must have power at the switch if not then the problem is before there. The feed to the switch is a brown wire which should be constantly live as it comes from the same source as the feed to terminal 3 via the starter solenoid, there is no fuse!
A multi meter on terminal 3 (left side 2nd one down) would be a good start if you have 12v there then try turning the switch on to see if you get any voltage on the bottom terminal same side (7).
The wiring diagram shows the brown wire as being commoned up on terminal 3 with the incoming feed from the battery, mine is so I would check that is on yours and that it is solid, mine broke off today as I was removing it for repairs (see my project thread as its all about what you are doing).
I made an idiots guide that I will try and upload for you now, it should help you a lot!
Edited by CityEPete, 28 December 2013 - 06:32 PM.
#10 CityEPete
CityEPete
  • 3,920 posts
Posted 28 December 2013 - 06:18 PM
here you go
#11 CityEPete
CityEPete
  • 3,920 posts
Posted 28 December 2013 - 06:26 PM
You can see the flasher is fed via fuse 3-4, thats why that still works so I doubt its the stork as you would get either dip or main from the rocker on the dash if it broke in one position or the other, more likely you have no power either in or out of the rocker on the dash.
The rocker connections are
Brown- positive in constant live no fuse remember
Blue- feed to stork for dip and main and also the inline fuse for the fog light (this is your problem imo)
Red- feed to fuse 7-8 , all the dash lights and side lights etc.
If you have dash lights you have power into the rocker for a start, see where that gets you. You could find all manner of after bodge fuses/relays etc especially if its had spot lights and stuff.
#12 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 28 December 2013 - 06:28 PM
if you checked there is no bare metal wire touching the car? my headlights kept touching the metal headlamp bowl so i cut a section out and now it works :)
#13 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 December 2013 - 07:00 PM
  Pull the light switch out of the dash, it's probably a bit melted at the back.  There are no fuses or isolating relays in the headlamp circuits as standard (other than the fuse shown above for the flasher), some cars have a dim-dip relay but it can't cause this level of failure.
#14 welldc
welldc
  • 92 posts
Posted 28 December 2013 - 11:50 PM
There are on mine...................and they look original. Same as the ones on the bulkhead.
As an aside, can anyone tell me if a 93 Mayfair would have had halogen headlights originally, and if not, is the original wiring good enough for modern day halogens?
#15 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 29 December 2013 - 12:36 AM
If yours is a 4 fusebox car then having the lights fused on one fuse is dangerous and should be removed and a solid connection made, the only Minis that had the headlights fused were the later cars with the 24 fuse fusebox and they were fused side for side so you dont loose all lights if a fuse blew.
