Ah I see thanks for your help! It's an '88 998cc City E. Thanks for the help CityEPete! I'm thinking of taking it to a local garage to see if they can have alook at it as being honest I don't really have an area to work in. Thanks for the help I might try and fiddle a bit though! The sidelights/indicators work fine but the rear lights and the dash lights don't work. It's a four fuse box but I think it is only wired to three fuses in the box, the missing fuse has no connections to it. It's a bit 'naffly' wired this car to be honest.
#16
Posted 29 December 2013 - 07:37 PM
#17
Posted 29 December 2013 - 08:49 PM
#18
Posted 29 December 2013 - 08:56 PM
#19
Posted 29 December 2013 - 09:03 PM
You can see most of the connections from this, the blue terminals were all ones that were either broken or just holding together, any similar on your car (almost identical to mine age and spec wise) could be at least contributing to this problem.
Let me know if you need a list of all the colours
Edited by CityEPete, 29 December 2013 - 09:07 PM.
#20
Posted 29 December 2013 - 09:13 PM
#21
Posted 30 December 2013 - 05:21 PM
Ah thanks for that! I'll try to take a picture tomorrow :) The diagram helps thank you :) I'm taking it to an electric specialist tomorrow to see if they can address the problem. But it does need to be wired correctly like your photo rather than just wired to just three fuses like mine is.
#22
Posted 31 December 2013 - 02:12 PM
Thanks for your help guys! Turns out the fusebox connections had burnt out
And it has now been wired more properly to 4 fuses :) Thanks again you've been a great help :)
#23
Posted 31 December 2013 - 03:04 PM
Everything working now then ?
#24
Posted 31 December 2013 - 03:16 PM
dont some people spray them with WD40 after cleaning them to waterproof them?
#25
Posted 31 December 2013 - 07:37 PM
#26
Posted 11 January 2014 - 11:06 PM
Ah I see thanks for the tips! Works fine and dandy! ![]()
#27
Posted 12 January 2014 - 10:26 AM
It appears to be attached to the rear of the engine
Mini Technical Sections →
Problems, Questions and Technical →
Turn Signal/indicatorsStarted by oldman1001 , 30 Sep 2026 |
Spi Auto Keep Dying After About 15 Mins Of Driving. Ideas?Started by Lilgreenmini , 28 Mar 2026 |
Question About WiringStarted by Chekako , 07 Feb 2026 |
Timing Scatter ? Two Marks On The Pulley At The Same Time…Started by corsicanwood , 21 Jan 2026 |
Auu1086 DizzyStarted by Sharks , 09 Sep 2025 |
