Hi I am looking at using a bulkhead connector to wire up my windscreen wiper motor . what amperage will it need to be ? Can anyone tell what part to use ?
Posted 09 January 2014 - 06:55 AM
Posted 09 January 2014 - 10:29 PM
Hi I may be thick but I don't understand where the bulkhead connector comes into play wiring up your wiper motor? the original wiper motor uses a male plug on the loom into a female on the motor assemble. Is yours damaged and you want to use something suitable ?
Posted 09 January 2014 - 10:35 PM
It's a 14W wiper motor so the running current is about 1.2A at 12V (or 1A with the engine running). That's the running current though and the stall current and startup current are far higher so use something decent, wiper blades frozen to the windscreen have started many car fires! All 5 cores are needed for the 2 speed motor.
Posted 09 January 2014 - 10:42 PM
Posted 10 January 2014 - 06:48 AM
Hi, no one could call you thick,you know you stuff ! I could have phrased the question better. It's in a motor sport mini so it's non standard. Would you say a 5 amp connector should be high enough or do I need to goto 10 amp. (The RS parts list is too long!)
Posted 10 January 2014 - 01:04 PM
10 amps! A stalled motor will easily exceed 5 amps.
Posted 16 January 2014 - 12:04 PM
I hope you have the PROPER (and expensive) crimp tool, as otherwise the connections will turn out to be extremely unreliable. That is true of any kind of crimp, and the range and cost of tools that are needed is the biggest reason for not using them. There is no easy and satisfactory solution to that problem. Sometimes, soldering is a possibility.
If you stick to a standard type of AUTOMOTIVE connector it will be far easier to find someone with the correct crimp tool.
Posted 16 January 2014 - 06:18 PM
Not a problem, this one is designed to be soldered. I do take your point buy a inexpensive part, then spend loads of money on the right tool.
Posted 16 January 2014 - 10:12 PM
Yes, maybe £200 for certain crimp tools is not funny. I am glad that you will be soldering it. I would just not like to think of a needless fire being started by defective crimps, which does happen from time to time, and not just in cars.
Mini Spi Charging IssueStarted by Dutch_MiniSPI , 27 Mar 2024 electrical |
Main Dipped Beam Not Working - Just Before Mot :-(Started by Park , 24 Mar 2024 electrical |
Speeduino EcuStarted by cooperpooper , 09 Mar 2024 electrical, engine |
Smiths Electronic Speedo Accuracy?Started by chuee , 01 Mar 2024 electrical |
