Hello
Got a 1987 Rover and the fuel gauge is not working what so ever. Need to get it through an MOT but want to try and fix it myself first.
Posted 11 June 2025 - 01:45 PM
Posted 11 June 2025 - 04:43 PM
Do you have a Volt or Multi-meter ?
If not, perhaps an old Brake / Stop bulb with one working filament with a length or flex?
The hand-books used to have a wiring diagram in the back, with a code to the wire colours.
The current goes from the battery, via the starter solenoid, on to the ignition switch; if all the other usual things work when the ignition is switched on, then the wiring is OK as far as the ignition switch. From there it goes via a fuse to / through the Fuel Gauge and on to the back of the car, to / through the sender / float in the tank, to earth.
If it is only the Fuel Gauge that isn't working, it isn't likely to be the fuse, but worth removing the fuse and checking.
With age, dust and corrosion can block the current, so moving the fuse or any connectors, just might cure the problem.
Go to the boot and gently pull the wire off the sender / float and test for current between the wire and earth. If there is current to the tank, it is either bad earth or the sender / float is faulty.
If there is no current to the boot, you'll have to start searching behind the Dash.
Posted 11 June 2025 - 05:13 PM
Posted 11 June 2025 - 05:29 PM
Hope this helps
Mini Technical Sections →
Problems, Questions and Technical →
Smith Temp Gauge ModificationStarted by oldman1001 , 06 Oct 2026 |
Turn Signal/indicatorsStarted by oldman1001 , 30 Sep 2026 |
Spi Auto Keep Dying After About 15 Mins Of Driving. Ideas?Started by Lilgreenmini , 28 Mar 2026 |
Question About WiringStarted by Chekako , 07 Feb 2026 |
Timing Scatter ? Two Marks On The Pulley At The Same Time…Started by corsicanwood , 21 Jan 2026 |
