Vw Engine Conversion Into Clubby
25 replies to this topic
#16 dazzler-pws
dazzler-pws
    Previously known as ringonezero
  • 167 posts
  • Local Club: Minifinity
Posted 14 January 2014 - 01:48 PM
Interesting conversion, but why the plan for 15's?
Are you planning to build the frame in such a way that if you wanted to fit either the later 16v versions or the G40 lump it would be a simple swap
Hi Craig
Wheels couple of reasons really
1 Gearing (for economy)
2 Tyre cost (£38)
3 Wheel Type/cost Sports pack replicas to the untrained eye
4 Ground Clearance (can run the car with a good "look" wheels close to arches but will be higher off the ground for town driving and rough roads in europe on and off ferry etc)
Frame
I haven't seen the other engines to comment but the base frame I made would/could fit nearly any 4 pot in I would imagine
The build brief from Father was to make the car as one of my old minis (77bhp/100lbft), will be able to return good MPG (this engine in the seat is at 45mpg, so expecting well over 50 in the mini), He wants to go 15k between maintenance on the motor hence ditching the mini ball joints and wheel bearings, and he wants it quiet.
This isnt your typical engine conversion, Yes this engine could have a turbo strapped to it, a cam and manifolds etc and be good for 150+BHP+
Also the doner car cost £75 and was driven to where it was stripped, engines float for small money its not worth maintaining an A series at that sort of money
#17 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 14 January 2014 - 06:20 PM
Ah, makes sense. Whats your plans on the back end (thinking longer maint periods and clearance for the bigger dia tyres?
Did you see you old PPC £999 challenge mini was on the bay the other week?
#18 dazzler-pws
dazzler-pws
  • 167 posts
Posted 14 January 2014 - 06:25 PM
I saw it about 6-8months ago, didnt realise it was back on again.
Not 100% sure yet will see what turns up, I fancy a torsion bar type beam but will sort that end when I get there
#19 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 19 January 2014 - 04:28 PM
Like the wheel choice. Almost sportspack styling.
Will be following this thread.
Great stuff
#20 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 20 January 2014 - 03:36 AM
One of the rear suspensions out of a little Peugeot then like the 106 or the 205? the car widths are wider than the mini but not much (10cm to 17cm  or so) the layout looks very compatible with the mini and the weight would be in the ball park for a clubman (Peugeot rear end might be heavier I don't know? )
the 106 wiki says one came out with 14" wheels so the suspension might cope OK with your wheels...?
#21 tiger99
tiger99
  • 8,584 posts
Posted 22 January 2014 - 05:57 PM
Torsion beams are nowhere near as good as the standard Mini setup, and were introduced on cars where cheapness and nastiness were considered to be good qualities. I can't see why it would be worth the effort to fit one. Also, as you can't cut and weld any part of the beam (MOT failure, and it would invite fatigue failure), you are stuck with the width, and the length of the equivalent to the radius arms. There is a fair bit of flexing, which causes toe change, and we know how sensitive the Mini is to incorrect rear toe.
I do like to see innovation in modified cars, but I think you would be better to put the effort elsewhere. On the other hand, the best ever FWD rear end, the multilink system used on the Ford Focus and subsequent models, would be an engineering challenge which could bring much reward in terms of handling, at the expense of most of the already minimal boot space, and the need to relocate the fuel tank.
But again, a huge amount of extra work....
#22 dazzler-pws
dazzler-pws
  • 167 posts
Posted 23 January 2014 - 07:15 PM
Hi cheers for the input.
Rear end is now going to be mini subframe with metro arms.
Being busy doing administration type stuff towards the Build removing stuff from doner and collecting other parts.
Will have a proper update with engine hung in frame towards start of next week
#23 dazzler-pws
dazzler-pws
  • 167 posts
Posted 27 January 2014 - 11:48 PM
Ok...
Been doing much administration type stuff towards the build, gathering parts and removing parts from the doner
a few pics
1546433_10151905553497817_144669228_n.jp
1601403_10151935566757817_407010318_n.jp
1014406_10151935567057817_1925912598_n.j
1623700_10151935567187817_1816668844_n.j
another example of what not to do, wheel spacer with std studs
1466036_10151935566842817_2066109222_n.j
Picked up these from Bingley
1743521_10151935559467817_1446681397_n.j
So first "problem" to work around, the cam side doesnt have any provisions for a side mount, factory this was done at the rear, we dont have room at the back, started to mock something up... probs will start a fresh i dont like it
1609673_10151935566647817_739781782_n.jp
#24 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 28 January 2014 - 09:50 AM
new wheels look good
#25 dazzler-pws
dazzler-pws
  • 167 posts
Posted 04 February 2014 - 09:50 AM
Ohh... so i haven't updated in a while mainly because we have been trailing some engine mounts and positions.
Big result managed to get the factory mount fitted behind the sump, its one and that side of the engine is supported, Although the gearbox end is also supported, I dont like it and will be redoing it.
Progress seems slow but we are doing 2 evenings and a saturday each week on it!
#26 1293gt
1293gt
  • 322 posts
  • Local Club: nonw
Posted 14 February 2014 - 12:02 PM
Nice seats
