Hi, my minis distributor has packed up so need a new one, cant tell which one i need though as its a 1980 (V Reg) and apparently this was the year they swapped from A to A+. its dated 19/05/1980, im wanting to replace my old dizzy with an electronic one but dont want to spend £60+ on the wrong thing. Anybody know the exact date they swapped over? Or could reccomend a not too expensive dizzy replacement please? Thank you
Posted 11 January 2014 - 12:42 PM
Posted 11 January 2014 - 12:49 PM
you can tell off how the distributor is fixed if its a forked clamp its a+ or if its a round ring with a nut and bolt its a series
why dont you buy an electronic ignition kit off ebay at around £20 and fit it in your own points distributor they work great and then throw points and condensor in the bin
thanks phil
Posted 11 January 2014 - 01:14 PM
thanks phil
something like this?: http://www.ebay.co.u...=item3a8500f671
Posted 11 January 2014 - 01:23 PM
Conversion kit going for nothing here, not sure if its right for your distributor but its a bargain!
http://www.ebay.co.u...=item27dd2640bf
Posted 11 January 2014 - 01:24 PM
hi same distributor as landrover item no
Posted 12 January 2014 - 10:49 PM
Slightly confused as I thought my engine was a late A series, but just checked and i have the forked clamp to the dizzy (which makes me think its a+ series) but points are blue which i thought were a series?
Is it possible its an a+ series and someone used the wrong kind of points?
(Im looking into electronic ignition kits but im totally confused as to what i actually need now!)
Posted 13 January 2014 - 09:45 AM
Blue points are from a 59D dizzy instead of a 45D - they should last longer as they slide about a bit.
Externally they look identical, so you'll need to clean off the sides and look for the stamped identification marks.
Posted 13 January 2014 - 10:03 AM
45D distributor is used on the pre A+ engines. the later engines have easily identifiable ribs on the block which are meant to make it stronger or something, pre A+ will be a lot smoother. I found when I was trying to change my points, the colour on the points can have absolutely no bearing as to what distributor it is as I tried to get new points and the mini expert I took the old ones to had never seen points like mine and we went through his supply to find ones to fit
pre A+ looks like this:
hope this helps. I also got the accuspark conversion but I regret not just going fully electronic as I've still had problems.
Adam
Posted 13 January 2014 - 11:29 AM
Also note the big alternator bracket on that A, as the casting was designed when dynamos walked the earth. The A+ one is about as long as it's tall. The points are interchangeable, so a poor indicator. Depends what's up with your dizzy whether a leccy kit will fix it.
Mini Technical Sections →
Problems, Questions and Technical →
Crank Damper For Ribbed Belt PulleyStarted by BaronVonchesto , 01 May 2024 engine |
Tapping Noise At IdleStarted by Sterling M , 27 Apr 2024 engine |
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
