Can't fit my seat belts after fitting a roll cage.
#16
Posted 30 May 2006 - 01:10 PM
#17
Posted 30 May 2006 - 01:33 PM
#18
Posted 30 May 2006 - 03:46 PM
#19
Posted 30 May 2006 - 04:32 PM
Just a thought straight of the head, have not tried it and it may or may not work.
How about taking the pasenger belt and fitting it on the outside of the driverside bin using the original mounting, also doing the same for the passenger side??
Like I said just a thought and may be unsuitable
Fitting any safety device as NOT intended is dangerous.
In which way is that NOT intended??
Or you can do what I'm doing. Chop out the rear bins, and add an anchor point for the reel in the inner sills. (just in case my choice of harness may not be so road-friendly.....)
According to a previous post, wouldn't this be fitting a safety device as NOT intended???
#20
Posted 30 May 2006 - 04:50 PM
#21
Posted 30 May 2006 - 05:14 PM
I would hope not! The device is being fitted as the device is intended, though it's not fitted in the configuration of the orginal vehicle. Is that "dangerous" or "illegal"...? I doubt it! I've also consulted with my friendly neighbourhood MOT man on this, and he has said that as long as it is a solid fixing (and surroundings), and that the seatbelt functions how it should do, then he can't see a problem.
While I see no qualms with what you were suggesting, I would think it's better to fix the cause of this particular problem (as to my mind it means that the cage is not fitted properly! THAT could be construed as dangerous.) rather than fixing the ensuing problem.
As for not being able to fit the reel into the space, the door bar is removeable and once removed will easily allow access to the area.
#22
Posted 30 May 2006 - 05:23 PM
fairynuff just a thought
#23
Posted 30 May 2006 - 05:34 PM
I'm pretty sure that the cage is fitted wright.
I've had a go at fitting the reel to the outer side of the bin but when closing the door it fouls the reel.
I really didn't want to fit harnesses as I want to keep the rear seat.
I've been thinking along the lines of fitting the reel to the outer side of the door bin but on the other face,sort of where your feet would be when sitting in the back.
Someone mentioned that they had a word with there local MOT guy,is there any minimum metal thickness or guidlines I sould follow,I'll go down tomorrow and have a would with my local guy but would like to do some sketches tonight and have a rough idea for tomorrow.
Thanks again,
#24
Posted 30 May 2006 - 05:36 PM
#25
Posted 30 May 2006 - 05:41 PM
So does it actually look like the picture that I posted of Jammys cage?
No,the gap is alot smaller,I would say inch and a half maybe two at the largest point.
#26
Posted 30 May 2006 - 05:45 PM
Up to you though, but I don't think the MOT man will consider fitting the reel to the side of the bin as "safe" on the original there are two big brackets that hold the reel to the structure of the car. You'll need a lot of steel in there to tie it back to the sill to the point where the MOT man is satisfied. IMHO.....
#27
Posted 30 May 2006 - 05:48 PM
#28
Posted 30 May 2006 - 06:01 PM
If I put the cage any further back,for the rear leg to be on the arch,the front leg (the one in the bin) will have about an inch or so gap between ,it,and the floor.I'll have a look tomorrow and see but I can't see it moving back.
#29
Posted 30 May 2006 - 07:22 PM
#30
Posted 30 May 2006 - 09:18 PM
Do you still have the wheel-well padding & cover under the foot? that will make a difference, as well as any little deformation in the shape of the well.
It is just a fettling thing. You'll find that you move something a little tiny bit expecting it to make no difference, and suddenly everything moves an inch. Just have a go at shuffling things around to try to replicate the numbers on that pic as best you can.
