Hi, before I have to get under the dash, what do you think the problem may be. The fan works fine on the second speed,but not at all on the single speed. Is this a case of, if the wire has not fallen of the back of the switch, then it must be the motor ?
Posted 13 January 2014 - 08:33 PM
Posted 13 January 2014 - 08:36 PM
I would check the switch first. The motor isn't a two speed motor, there is a resistor on the side of the case near the back. Perhaps the resistor has failed, or a wire has come off.
Phil.
Posted 13 January 2014 - 08:42 PM
there is a little resistor wire in the heater under the cover. they often break over time. cut it out and fit a resistor in its place. i used this type.
http://www.ebay.co.u...R-/290950613664
a bit over kill but it will work forever.
Posted 13 January 2014 - 09:21 PM
Mine has this issue, but works great when I ram my fingers into the back of the switch, wiggle them about a bit. This is a very technical procedure, do stop me if I get a little too in depth. ![]()
Mini Technical Sections →
Problems, Questions and Technical →
Smith Temp Gauge ModificationStarted by oldman1001 , 06 Oct 2026 |
Turn Signal/indicatorsStarted by oldman1001 , 30 Sep 2026 |
Spi Auto Keep Dying After About 15 Mins Of Driving. Ideas?Started by Lilgreenmini , 28 Mar 2026 |
Question About WiringStarted by Chekako , 07 Feb 2026 |
Timing Scatter ? Two Marks On The Pulley At The Same Time…Started by corsicanwood , 21 Jan 2026 |
