Thanks in advance for your help!
Jonny
Posted 29 January 2014 - 11:09 PM
Posted 29 January 2014 - 11:21 PM
Posted 29 January 2014 - 11:24 PM
Posted 29 January 2014 - 11:26 PM
Not sure what year etc, but on mine I would change
Inline fuse, under the scuttle, purple and orange wire, 15a fuse, this is hazard lights and interior light
And the horn and heater are on different fuses
3rd fuse down 25amp Horn, Headlamp Flasher, Brake Failure Circuit & Radio Memory.
4th fuse down 5-6 25amp Heated Blower Motor, Windscreen Wipers, Washer Motor & Instruments.
Fuses and whats covered on each is here http://www.theminifo...s-covered-data/
Posted 29 January 2014 - 11:28 PM
Posted 29 January 2014 - 11:32 PM
Edited by jonnyenglish, 29 January 2014 - 11:33 PM.
Posted 29 January 2014 - 11:35 PM
should be
35a
25a
25a
15a
As far as I recall, I replaced fuses more times than I drove the bloody thing, so I think that is the right order for your car. But like I said, change the inline fuse behind the air filter, purple and orange wire, 15a fuse
Posted 30 January 2014 - 12:01 AM
Posted 30 January 2014 - 03:55 PM
sometimes when i get horny i flashy too
Posted 30 January 2014 - 04:51 PM
And then you blow a fuse!
Posted 30 January 2014 - 07:38 PM
well im sure youll all be dying to no whether i found a dead fuse or not! well i did the inline 15a one was out for the count so changed it and well it made no difference sill no horn still no interior light or hazards also i have the added benefit of never being able to turn off my lights even if the key comes out the ignition! wooooo think this needs a proffessional another thing worth noting is that the wipers dont wipe and the washers dont jizz all other fuses are fine really confused!
thanks
jon
Posted 30 January 2014 - 08:11 PM
also worth noting is that during this time a radio and electric aerial have been installed could this have caused the problems?
thanks again
jon
Posted 30 January 2014 - 08:25 PM
who fitted the stereo? have you tried unplugging the stereo and if things work when it is disconnected.
Posted 30 January 2014 - 08:57 PM
