Hi all,
The mini was delivered to me on a flat bed, the car came from repo company without much paperwork,
Ive not contacted the prevous keeper yet because he's miles away....
so far I have installed new battery, removed starter and cleaned and refitted, also check the earth terminals,
ive tried attatching a earth strap directly on the starter but still only clicks when I use spanner on rear terminals of the motor,
when I remove starter motor out of the gearbox and test it its moves fine and turns at high speed,
ive also tried the rocking method, car in 2nd gear and push forward/backwards still cannot see the fan moving, ive tried a large screwdriver on the flywheel and it don't turn
the above method was tried with the spark plugs removed, I noticed 3 sparkplugs were very dry and maybe little sign of rust on them.
Whats next,
This is my first mini and really want to get it going.
