Hi, came across this manifold after deciding to run twin hs2's rather than hs4's. It looks lovely after a quick clean and paint.
A few problems have come to light now its on the car, firstly what can I do about the throttle cable, standard manifolds have the little bracket. What do people running Maniflow manifolds do?
Secondly the Maniflow lcb exhaust flange is thicker than the manifold flange where they attach to the head. What's the standard practice for a problem like this? Am I best to fabricate a spacer between the head and the intake manifold or is there a simpler option.
Thanks for your help guys, I'm almost there now!
IMG_20140304_210533.jpg 96.43K
31 downloads
3 replies to this topic
Posted 04 March 2014 - 01:08 PM
Posted 04 March 2014 - 01:16 PM
I have bolted the throttle bracket at the back, to the elbow bolt of the front carb.
Posted 04 March 2014 - 01:51 PM
Ok thanks. Any chance of a picture if you can? Thanks.
Posted 04 March 2014 - 03:25 PM
If the thickness is different between the two manifolds you have two choices - easiest is to fabricate some washes that have a step on them - or take the lcb off and grind some slots to take the thickness down.
Mini Technical Sections →
Problems, Questions and Technical →
Crank Damper For Ribbed Belt PulleyStarted by BaronVonchesto , 01 May 2024 engine |
Tapping Noise At IdleStarted by Sterling M , 27 Apr 2024 engine |
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
