Check Strap Seal
#16
Posted 12 March 2014 - 08:17 PM
#17
Posted 12 March 2014 - 08:49 PM
Mine is a 1979.
These that I bought were for 1970 - 1986 models.
#18
Posted 12 March 2014 - 09:11 PM
I did own a 1980 years ago but my last 4 have been the later after 86 version which clip on so I am not sure, anyone got any pictures to help out pusb?
#19
Posted 12 March 2014 - 09:15 PM
Ooo Ooo, me, me...
I think that may help, I had no pins on mine, I put some double sided sticky tape on the back and stuck it to the door.
#20
Posted 12 March 2014 - 09:23 PM
#21
Posted 12 March 2014 - 09:26 PM
Thanks Alex.
I might just use some silicone to put it on.
#22
Posted 12 March 2014 - 09:31 PM
Thanks Alex.
Like pete said I may have put them on the wrong way (anyoneone confirm this?) I had the problem of when the door was shut the check strap seals overlapped the door seals so may be better puting the the other way around?
Edited by alex-95, 12 March 2014 - 09:31 PM.
#23
Posted 12 March 2014 - 09:36 PM
#24
Posted 12 March 2014 - 10:03 PM
Thanks guys. I will probably get a chance to look at it Friday so hopefully I can get it fitted ok.
#25
Posted 14 March 2014 - 12:39 PM
#26
Posted 15 March 2014 - 10:35 AM
#27
Posted 15 March 2014 - 01:03 PM
#28
Posted 15 March 2014 - 01:27 PM
I think you can fit them to any car mate, I had to poke out the little pre scored holes for my pegs to go in, if you dont have any dont poke them out, peel off the backing and stick them on to the body not the door, make sure its clean and dry first and job done ![]()
#29
Posted 15 March 2014 - 01:29 PM
http://www.minispare...h/classic/check seal.aspx|Back to search
Here you go, will fit all wind up window cars, they are handed though so make sure you get both ![]()
#30
Posted 15 March 2014 - 04:32 PM
I've given the ones I bought a bit of a trim with a Stanley knife and they seem to fit now. Looks like its still a good tight fit so I will see how it goes.
If it still leaks I will give those other ones a try.
