Posted 13 March 2014 - 12:51 AM
Posted 13 March 2014 - 06:57 AM
Posted 13 March 2014 - 08:37 AM
ii ,can som1 tell me how to reset ecu thank u,brian
If it needs resetting, disconnect the battery and leave for 30 minutes. That should clear the ECU, far as I'm aware. Howcomes you need to reset it?
Posted 13 March 2014 - 08:44 AM
Unfortunately, this method won't clear any fault codes. To do that, you need a fault code reader, of which there are many members on here including myself with one
Posted 13 March 2014 - 08:48 AM
If it needs resetting, disconnect the battery and leave for 30 minutes. That should clear the ECU, far as I'm aware. Howcomes you need to reset it?ii ,can som1 tell me how to reset ecu thank u,brian
Oh really?? I always was under the assumption disconnecting the battery did clear the faults. Fair enough, I may have to invest in one of them myself
Posted 13 March 2014 - 08:59 AM
Oh really?? I always was under the assumption disconnecting the battery did clear the faults. Fair enough, I may have to invest in one of them myselfIf it needs resetting, disconnect the battery and leave for 30 minutes. That should clear the ECU, far as I'm aware. Howcomes you need to reset it?ii ,can som1 tell me how to reset ecu thank u,brian
Disconnecting the battery just clears what the ECU has learnt about the engine, fault code readers can be bought on eBay for between £100 and £200. Popular readers are made by Sykes Pickavent and Crypton
Posted 14 March 2014 - 09:32 PM
Mini Technical Sections →
Problems, Questions and Technical →
Smith Temp Gauge ModificationStarted by oldman1001 , 06 Oct 2026 |
Turn Signal/indicatorsStarted by oldman1001 , 30 Sep 2026 |
Spi Auto Keep Dying After About 15 Mins Of Driving. Ideas?Started by Lilgreenmini , 28 Mar 2026 |
Question About WiringStarted by Chekako , 07 Feb 2026 |
Timing Scatter ? Two Marks On The Pulley At The Same Time…Started by corsicanwood , 21 Jan 2026 |
