Hi everyone, feeling really depressed about this.
1275, Hif44 carb, standard pretty much everything.
New distributor, new plugs and leads, carb recently set up from scratch, new battery, timing redone when distributor replaced.
So recently had lots of ignition problems but for the past month has been driving pretty sweet, although always felt down on power. Yesterday I pulled into the carpark at work and it started shuddering, shaking, running like a tractor.
Got the engine idling and pulled out the HT leads one at a time. Removing leads 1 and 4 made the problem much worse (so assume these are good), removing 2 and 3 made no difference. I swapped the plugs over and no difference. I could hear the spark in the leads too, so safe to say it's the cylinders themselves. I have just ordered a compression tester, but it seems pretty obvious what the problem is.
So this weekend it'll be the head off (I'm a bit scared) and I hope to see the gasket has blown between 2 and 3.
My question is, is this all it is likely to be? While I've got the head off, what else should I be looking for? I don't really know a lot about valves etc and my biggest fear is replacing the gasket and it not being fixed!
