Weber 45 Query?
16 replies to this topic
#16 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 22 April 2014 - 08:14 AM
You need vacuum advance on any road car, unless its a full race engine in which case it will have a totally different distributor curve to suit. Regards to extra grunt from a weber, setup correctly there will be little difference between a pair of SUs of 1 1/2" (yours in the picture by the way are 1 1/4s and would restrict th bhp on a well sorted 1330) and a weber 45 except at the very top end of the rev range. Check Vizards book on the graph and its only a few bhp were talking about.
So back to your question it depends on what the spec is of your engine, if its built to 1275s spec and about the same BHP (75) then the SU 1 1/4s will be ok and fitting the weber will do little, if on the other hand your motor is built and your expecting 100bhp then the weber would not be restrictive like the little SUs
The vac take off is quite important as if its sited in the inlet manifold then its subject to a higher vacuum then if its sited slightly behind the butterfly as per SUs and in Bungles Dellortos above. They started fitting later cars with the vacuum takeoff in the manifold for emission reasons as at a given rev it produced more vacuum advance which was a attempt to clean up emmission readings. The problem with it being in the manifold is induction pulsing which upsets idle and the sportier the engine the worse it becomes. Your problem is the Weber was sold as a racing carburettor and is not drilled for a ported vacuum take off, which is only there to aid economy.
Not really but it will "see" vacuum faster. I've seen cars with little brass orifice nipples to smooth out the way vacuum is transferred
#17 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 22 April 2014 - 09:05 PM
Rover actually used manifold Vacuum on the MG Metro see full article herehttp://www.minispare...c8-51ce2df2fe57
quote by Keith Calvier
Classic example - the MG Metro. Its adventurously sporty cam makes for a slightly lumpy idle. This increases idle speed emissions, so Rover use manifold-sourced vacuum to increase idle speed ignition timing via the vac advance. We're talking 28 degrees of ignition timing here! Doesn't work because the pulsing created by the cam causes erratic ignition timing, culminating in running on. So an anti-run-on valve was fitted as a modification. Vicious circle. After messing about trying to solve the emission problems this caused, it was found that changing the originally quoted valve clearances to 0.014"inlet /0.017" exhaust (effectively reducing the cam over-lap) helped dramatically. And, like I said earlier, the sportier the profile, the worse it becomes. Even worse - when running, this system can cause ignition advances in the order of 50 degrees on lift-off and on again - an absolute sure-fire recipe for savage detonation.
