I'm currently building a 998 engine, well the short block is built up, +.060, wedged/bladed crank, lightened rods, Kent 276 cam, MED lightened flywheel setup. The block is pocketed for exhaust valves.
The final part is the head and breathing of the engine, I have what I guess you would call a stage 4/5 12g940 head, the inlet ports have been opened up so much the push rod holes have been sleeved. Valves are 36/31 from memory(they might be 37/30, I'll check later) either way they are big. Exhaust ports are also large. (sorry I can't be more precise with measurements)
My main question regarding the head is, will something this modified work with the 998???
or would it be overkill, as theres only a finite amount of air the engine can breath? Should I look at buying a stage 3 940 head from somewhere like MED?
Or, I do have a standard 940 head...
As for the breathing side of things I was looking at using Specialist Components Fly-by-Wire setup or the 5 port injection setup, I was going to run Megajolt and an HIF44, but I have the money to buy the SC kit.
What are peoples thoughts on using the injection setup???
And finally the exhaust manifold.. I was going to use a Maniflow Cooper freeflow item, would this be enough for the head??? or am I going to need an LCB.
Basically I'm looking for the best inlet/head/exhaust setup with what I have if possible
The other option is bin the 5 port and go 7.... ;P Haha.
Any opinions and experience welcome!
Many Thanks!!
Edited by mini.rich, 07 May 2014 - 02:44 PM.
