Car Not Starting
electrical engine
4 replies to this topic
#1 WHarding
WHarding
    Just On Tickover
  • 8 posts
Posted 11 May 2014 - 11:48 PM
I have a 1992 Rover mini 1000 and it was starting up fine but was misfiring a little when running. I took the distributor out and cleaned it up as it was filthy and changed the distributer cap. Now i have it back in place the car seems to be turning over but will not start. It has worked since i put it back in but it would start and die very shortly after but with high revs it would keep going but when i took my foot off the accelerator it would cut out again. Now as i said it turns over but will not fire up at all. Any help would be much appreciated
Will
Edited by WHarding, 11 May 2014 - 11:49 PM.
#2 Dusky
Dusky
  • 5,322 posts
Posted 12 May 2014 - 05:39 AM
Connected the leads the right way?:P
#3 WHarding
WHarding
    Just On Tickover
  • 8 posts
Posted 12 May 2014 - 08:58 AM
Connected the leads the right way? :P
If only that was the problem but all spark leads are in the right way
#4 cal844
cal844
  • 9,717 posts
  • Local Club: TFMOC
Posted 12 May 2014 - 09:18 AM
You did set cylinder 1to TDC prior to dizzy removal?
#5 WHarding
WHarding
    Just On Tickover
  • 8 posts
Posted 12 May 2014 - 01:24 PM
i just took it out, i didn't adjust anything but it has run since i put it back in
Also tagged with one or more of these keywords: electrical, engine
