What Tools For A Rebuid
24 replies to this topic
#16 Shawbags
Shawbags
  • 159 posts
Posted 13 May 2014 - 01:55 PM
Am I right in thinking I will need a tool to remove the camshaft bush or is it a bearing ??.
#17 Gremlin
Gremlin
  • 2,142 posts
Posted 13 May 2014 - 02:05 PM
They are pressed in bearings, probably best to give your block to a machine shop for that so they can bore them out to your cam bearing sizes
#18 Shawbags
Shawbags
  • 159 posts
Posted 13 May 2014 - 02:12 PM
Just seen another stand , machinemart £84 340 KG thinking that would be better , few more quid but a lot safer I would have thought .
#19 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 13 May 2014 - 05:47 PM
If I am correct - any stand will work for a mini engine (obviously see manufacturers instructions for weight etc) But I was under the impression that an additional mounting plate is often needed to ensure the engine is fully supported on the stand using parts of the block that are sufficiently strong enough?
#20 Shawbags
Shawbags
  • 159 posts
Posted 15 May 2014 - 08:39 PM
Ok lads I've just picked my engine up , bloody heavy ! lol , put it in a wheel barrow , just the trick.
#21 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 15 May 2014 - 08:57 PM
Have a looksy below, nothing wrong with reading as much as you can to help you along the way, plenty of info out there. I think it also mentions in the thread below of picking up Bill Sollis's 1380 builder dvd, its got a complete gearbox strip/rebuild on there which is still one of the best and informative pieces I've seen for anyone whos been a bit afraid to tackle that part
Click me
Good luck
#22 Shawbags
Shawbags
  • 159 posts
Posted 15 May 2014 - 09:49 PM
Click me
Good luck
That's superb , thanks and cheers.
#23 frogeye
frogeye
  • 38 posts
Posted 21 May 2014 - 10:42 AM
I have a sgs 450 kg engine stand you can have for £5 if that's of any use. No good to me. In very good nick.
pm me if wanted
#24 Shawbags
Shawbags
  • 159 posts
Posted 22 May 2014 - 09:52 PM
If it's good for a mini engine yes , has it got all the bracket ? .
#25 SilverSaloon
SilverSaloon
  • 121 posts
Posted 23 May 2014 - 05:05 PM
what everyone else mentioned, plus Lots and lots of disposible gloves
mechanics hand cleaning stuff
