Knuckle Joints Vs Ball Joints
suspension
Best Answer sherly , 30 May 2014 - 01:35 PM
The component in the first link is a knuckle joint - goes between the upper suspension arm and the suspension trumpet.
The second link is the swivel hub balljoint, 2 fitted per side at the front these are fitted to the top and bottom of the hubs - I suspect it is these that need replacing, based on your description "upper and lower balljoints need replacing".
Pics would help wouldn't they!
Go to the full post
5 replies to this topic
#1 LilDrunkenSmurf
LilDrunkenSmurf
    Just On Tickover
  • 8 posts
Posted 30 May 2014 - 01:28 PM
Question relates to a '96 Rover Mini 1.3L SPi
Hi folks, question for all of you. When I had the mini inspected, I was told that both my upper and lower balljoints need replacing. I didn't think there was a difference, so I did some quick research and ordered 2 of these knuckle joints:
http://minimania.com...i-Cooper--front
I've had them sitting around, not thinking about it, but I'm going to take them into the mechanic that did the inspection, and while under the car the other day, noticed that there actually is a lower balljoint. Now my questions is, what's the difference between that knuckle joint, and these balljoints:
http://minimania.com...Upper-And-Lower
Based on the Haynes manual, it almost feels like the knuckle joint *is* the upper ball joint, but I can't really tell that easily. Could someone please explain the difference to me? I can't seem to find anything in the Haynes manual, or using my Google-fu.
#2 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 30 May 2014 - 01:34 PM
the first one is for your suspension trumpet/hi lo to go on (a knuckle).  The second is a ball joint for the top and bottom of the wheels hub.
#3 sherly
sherly
  • 704 posts
Posted 30 May 2014 - 01:35 PM   Best Answer
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,044 posts
Posted 30 May 2014 - 01:36 PM
the knuckle joint goes on the end of the trumpet an d the ball joint fits on the hubs.
#5 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 30 May 2014 - 01:38 PM
Hi,
The knuckle joints fit into the suspension cones in the front subframe tower and sit in the top of the top arm. On the top arm forward of the knuckle joint you will see a nut on the top of the top arm this holds the threaded portion of the ball joint in place, the ball joint itself being attached to the wheel hub, and there is then the bottom ball joint that you have seen. From what you say you need to purchase two sets of ball joints one pair for each front hub. I would advise you to buy the genuine ones from mini spares or mini spares own, as you get get them from lots of places but the quality may not be as good.
#6 LilDrunkenSmurf
LilDrunkenSmurf
    Just On Tickover
  • 8 posts
Posted 30 May 2014 - 01:55 PM
Awesome, that's exactly what I needed to know. Thanks!
Also tagged with one or more of these keywords: suspension
