The vacuum adds more advance at part throttle for better economy and performance when cruising
For initial setup of the mechanical advance:
Remove vacuum advance pipe
Check the advance at idle, 2000, 3000, 4000 and record the RPM where it stops advancing.
Hopefully you’ll get something like your 5-10 at idle, then a max of 30-32 degrees at 4000 with no more advance after that
Is vacuum advance never measured then? And is that 45 degrees at 3000rpm, with it still attached, anything to be concerned about?
Setting For Static Timing On 1275
scrumpymini
, Jun 04 2014 05:24 PM
17 replies to this topic
#16
Posted 11 November 2024 - 07:39 AM
#17
Posted 11 November 2024 - 07:44 AM
You need to set the mechanical advance first. Once you know that then you can check the total timing with the vac connected.
45 degrees at 3000rpm sounds decent for cruising
#18
Posted 11 November 2024 - 08:14 AM
Brilliant, cheers Timmy.
