Hey internets.
Quick question, I am in the process of rebuilding my gear shifter and wondered if all bottom plates have a hole in like the one in the picture? Also, any recommendations on grease when reassembling the linkage?
cheers
Best Answer Gremlin , 05 June 2014 - 11:40 AM
Mines got a hole, and doesn't look like it's been cut out by hand, so looks like they're standard, and do you mean where do I put the grease or what type of grease? Where do I put it? - Anything inside the box that moves including where it goes through the casing. What type do I use? - anything really, theres no outrageous forces involved Go to the full post
Posted 05 June 2014 - 10:44 AM
Hey internets.
cheers
Posted 05 June 2014 - 11:40 AM Best Answer
Posted 05 June 2014 - 12:17 PM
Great thanks
Mini Technical Sections →
Problems, Questions and Technical →
Crank Damper For Ribbed Belt PulleyStarted by BaronVonchesto , 01 May 2024 engine |
Tapping Noise At IdleStarted by Sterling M , 27 Apr 2024 engine |
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
