Yesterday I Bought My 1St Mini, And It's Died. :( Help.
#46
Posted 12 June 2014 - 01:38 PM
Some cars have them up behind the clocks inside instead, if not someone has been messing around I'd say.
#47
Posted 12 June 2014 - 02:04 PM
#48
Posted 14 June 2014 - 12:55 PM
I can not find these fuses anywhere.
So its off to the garage next week i think.
#49
Posted 19 June 2014 - 03:14 PM
Hi people.
sorry ive been a little quiet as of late, been busy at work and just not had time to check things out and update.
my hazards and fog light is still a non functioning status. my indicators are working and so is the interior light.
the fact the indicators work, leads me to believe from research, that my flasher unit must be fine.
both hazards and fog light not working im thinking could it be a bad earth connection?
im going to have a look around tonight see if that sheds any light.
im also going to take some pictures of my engine bay, im pretty sure its had some bodged efforts done where wiring is concerned. im also going to take some photos of the wires by my steering column, as I have no idea whats going on down there.
ill post them up and hope someone can help me out.
ive been reading up and im hoping I get this whole thing sorted by the weekend.
in other news I managed to fix my horn.
minor I know, but its the first thing ive fixed by myself. I have zero experience fixing things on cars so to me it was a step in the right direction.
ive also spotted an oil leak now, I think its coming from my sump, im guessing that means its cracked somewhere?
people were not joking when they said id learn mechanical car care when I buy a mini.
not a very good update for you guys but im trying, im determined to sort this bloody hazards issue out.
it doesn't help I don't really know what im looking at, so its probably screaming in my face.
ive been reading up about people swapping fuse boxes over to bladed fuse boxes from Halfords and this helps solve problems. it may as well be Chinese for the good it does me reading it, just wondering is this something I should look into a bit more?
dom.
#50
Posted 19 June 2014 - 03:46 PM
#51
Posted 19 June 2014 - 03:53 PM
Ill use this when I'm looking. I need to take some photos i think as im confident my wiring is different to every document ive seen. I just need to get my head round all the colours and where they all go etc.
I don't want to take it to a garage and them charge me a fortune to fix loads of dodgy wiring.
#52
Posted 19 June 2014 - 03:57 PM
BS wiring colours is in the FAQS here http://www.theminifo...ng-codecolours/
This will help identify what wire is going to what circuit.
#53
Posted 19 June 2014 - 04:59 PM
The fact the indicators work doesn't mean the hazard flasher is working, the mini has two flasher units, one under the dashboard that's for the indicators and one on the right hand side of the bulkhead to the right of the air filter that works the hazards, that is what I would change first personally as its cheap enough and if it doesn't fix it then you have a spare (which is worth having as they aren't the best quality)
#54
Posted 19 June 2014 - 05:41 PM
Would this stop my fog light working?
Im so bored of this problem, my massive lack of knowledge and newness to this isn't helping me either i don't think.
I'm going to do what I said. Take photos of the bits inside the engine bay and by my steering column, so people can tell me if its right infront of my face.
Thanks as always.
Dom.
#55
Posted 19 June 2014 - 05:59 PM
#56
Posted 19 June 2014 - 06:52 PM
