Running On 2 Cylinders Help?
Best Answer danny1 , 09 June 2014 - 04:28 PM
Like a stabbed rat, pulled up my drive and was almost uncontrollable on the lose gravel.
Has not mot ATM failed on emissions and wheel bearings so that's next weekends job when I'm back
But guys you were all a big help Go to the full post
21 replies to this topic
#16 Yoda
Yoda
  • 1,958 posts
Posted 09 June 2014 - 06:16 AM
Yeah plugs and leads are in the right order it's just not firring, I've just replaced the dizzy cap and rotar arm so there all new, I'll check the plugs tomorrow and see if it's that, I'll also try changing the leads over, but there brand new as we'll
This statement suggests that you should double check the firing order as per Dklawsons link and note that the order is:-
1342 counterclockwise. As Dk says if you have it wrong as per his description, it will give the symptoms you describe.
#17 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 09 June 2014 - 07:19 AM
If 1 & 2 are firing OK it can't be the points!
#18 danny1
danny1
    In the navy you can sail 7 peas
  • 1,321 posts
  • Local Club: bumpstart
Posted 09 June 2014 - 11:04 AM
Right leads were in the right order so removed all the plugs and I had spark at all of them obviously 1&2 were really wet so it was over fueling, so I adjusted the weber fueling and problem is solved. Quick test run and it's seems to be sorted.
Thanks for the help guys
#19 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 09 June 2014 - 12:06 PM
I know that's a typo. :-)
DOH!  YEP!  Sorry... thanks for catching that.  Original post edited.
#20 cal844
cal844
  • 9,624 posts
  • Local Club: TFMOC
Posted 09 June 2014 - 12:47 PM
No problem, good to see its fixed
#21 sledgehammer
sledgehammer
  • 3,098 posts
Posted 09 June 2014 - 04:18 PM
good news - what does it go like ?
bet the induction roar sounds good
Edited by sledgehammer, 09 June 2014 - 04:19 PM.
#22 danny1
danny1
  • 1,321 posts
Posted 09 June 2014 - 04:28 PM   Best Answer
