Twin Su Vacuum Advance
Best Answer KernowCooper , 11 June 2014 - 10:15 PM
Only problem with a Y piece and why is not used is if one carb is slightly ahead/behind of the first it would cause all sorts of issues with inconsistent vacuum one carb is ok
Go to the full post#1
Posted 11 June 2014 - 09:03 PM
Posted 11 June 2014 - 09:10 PM
Cheers james
Posted 11 June 2014 - 09:11 PM
Posted 11 June 2014 - 09:29 PM
Posted 11 June 2014 - 09:33 PM
I got 1 connection at each carb, but wouldnt using only 1 carb imbalance the whole system? :Pn
No, it's only after a presence of vacuum which is satisfied by one carb. Connect to one and block the other off, (doesn't matter which). Out of curiosity what are the numbers stamped onto the carb bodies?
Edited by petehuws, 11 June 2014 - 09:33 PM.
Posted 11 June 2014 - 10:09 PM
Posted 11 June 2014 - 10:15 PM Best Answer
Posted 12 June 2014 - 05:26 AM
Float chamber says AUD 2140 , but dont see anything on the carb body... Where on the carb body are the numbers?( they are still assembeled and on the manifold AEG 573)
Posted 12 June 2014 - 07:12 AM
luckily I still have my carbs off the car. Carb number is here on the outer of the body close to the float bowl. This is howing the LH side carb and numbered AUC871, the RH carb is AUC870 (on mine). The right hand AUC870 has the vacuum connection on my setup, there is no vacuum on the left hand AUC871.
Edited by petehuws, 12 June 2014 - 07:13 AM.
Posted 12 June 2014 - 11:06 AM
I have the same numbers( AUC 870 and 871) but they both have a vacuum
Posted 12 June 2014 - 12:40 PM
Posted 13 June 2014 - 03:11 PM
is this manifold worked at?
the rough looking ' parts' are actually way smoother than the rest
Edited by Dusky, 13 June 2014 - 03:12 PM.
Posted 13 June 2014 - 05:51 PM
Looks about the same, you have way better pictures though How do you light them?
Any pics of modified butterflies etc? :) Dont know how far I can go ( bit scared )
Posted 13 June 2014 - 05:53 PM
Il get some pictures of the butterflies and pistons for you
Cheers james
