Posted 22 June 2014 - 10:56 PM
Posted 22 June 2014 - 11:15 PM
What age car are we talking about?
Posted 23 June 2014 - 02:04 PM
It's an 1987 mini city e
Posted 23 June 2014 - 02:39 PM
LEDs of the normal type do cause some flasher units not to work correctly, but strange issue with the radio? The radio should be on a Ignition fed accessory circuit normall off fuse 4 ? have you checked all the connections to the radio are good? You might find changine the flasher relay to the 2pin with earth electronic type better. Re the dash lights possible you dislodged the multi pin connector on the back of the dash putting it back?
Edited by KernowCooper, 23 June 2014 - 02:40 PM.
Mini Technical Sections →
Problems, Questions and Technical →
Smith Temp Gauge ModificationStarted by oldman1001 , 06 Oct 2026 |
Turn Signal/indicatorsStarted by oldman1001 , 30 Sep 2026 |
Spi Auto Keep Dying After About 15 Mins Of Driving. Ideas?Started by Lilgreenmini , 28 Mar 2026 |
Question About WiringStarted by Chekako , 07 Feb 2026 |
Timing Scatter ? Two Marks On The Pulley At The Same Time…Started by corsicanwood , 21 Jan 2026 |
