Posted 22 June 2014 - 10:56 PM
Posted 22 June 2014 - 11:15 PM
What age car are we talking about?
Posted 23 June 2014 - 02:04 PM
It's an 1987 mini city e
Posted 23 June 2014 - 02:39 PM
LEDs of the normal type do cause some flasher units not to work correctly, but strange issue with the radio? The radio should be on a Ignition fed accessory circuit normall off fuse 4 ? have you checked all the connections to the radio are good? You might find changine the flasher relay to the 2pin with earth electronic type better. Re the dash lights possible you dislodged the multi pin connector on the back of the dash putting it back?
Edited by KernowCooper, 23 June 2014 - 02:40 PM.
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
