Now, when it came to the trumpets and cones, I stumbled across an issue. I'm going for Hi-Los, so just needed the cones. One was already off and looked decent enough - I asked on this thread. But the other was stuck fast to the trumpet (obviously had been on a long time). I tried levering it off without luck. I then tried to remove the knuckle joint - no joy there either. In then end I soaked it overnight in penetrating fluid, then did this:
I was then able to whack the knuckle out. I had a length of steel bar that was by chance just the right diameter, so I shoved it down the trumpet like this:
After some whacking, it came apart. The cone also looks half decent so I might refit them - I would ideally swap all out for new, genuine ones but at £160 for the set I'm going to wait..
So, I hope that the next post will show the rear subframe built up ready for installation.
Cheers,
Stu
