Posted 28 July 2014 - 12:15 AM
Posted 28 July 2014 - 08:32 AM
Your standard wiring if in good condition can take the upgarde to 55w bulbs now, your sealed beams were 45wx2 and drew 7.5amps, 2x 55w bulbs will draw 9.16amps, by all means fit relays to take the load off the standard switches (4 off), but there are hundreds of cars which had sealed beams running around converted to 55w Halogens without issues.
Edited by KernowCooper, 28 July 2014 - 08:33 AM.
Posted 28 July 2014 - 09:11 AM
ah, I thought the relay set-up was a must Dave. My wiring and connectors are all good and clean, I'll slip the 55's in and try them and keep monitoring the switch then. Bring on the night!
1987 Mini Rover Fuel Gauge IssueStarted by kwfranky , 11 Jun 2025 ![]() |
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
