Take out the jets one by one and clean them( poke trough them with a needle/guitar string,...)
Then try again.
Carb cleaner might also work. Was this weber recently installed?
Put it on today
Posted 11 August 2014 - 09:01 PM
Then try again.
Posted 12 August 2014 - 09:19 AM
Then try again.
Put it on today
If it was blacke then take the jets out and clean them, normally the weber should be able to be 'calmed down' enough .. Maybe it is sticking under the idle adjustment screw. Have you tried tunring it all the ways? ( all the way in/out?)
This is our jetting ( split weber 45 setup) for a 1330 with 310° cam.
68F5 STARTERJET
55F8 IDLEJET
Mainjet aircorrector (5)200
Mainjet : 130
F2 emulision tube mainjet
Mini Technical Sections →
Problems, Questions and Technical →
Cutaway Section View Of 7.5" Cooper S Caliper?Started by sandman , 01 May 2024 brakes |
Adjusting Brake Bias For 7.5" Discs With Pdwa ValveStarted by Daniel Watkin , 16 Nov 2023 brakes |
Answered
Fam7821 Brake Limiter Valve - Mounted Upside Down?Started by tarnofsky , 29 Sep 2023 brakes |
Kent 286 Can & MotStarted by frosty90 , 07 Sep 2023 brakes |
Brake Master Cylinder ReplacementStarted by M I N I , 30 Aug 2023 brakes |
