Posted 23 August 2014 - 07:59 PM
Posted 23 August 2014 - 08:10 PM
Edited by RedRuby, 23 August 2014 - 08:11 PM.
Posted 23 August 2014 - 08:21 PM
Posted 23 August 2014 - 09:17 PM
Edited by RedRuby, 23 August 2014 - 09:18 PM.
Posted 23 August 2014 - 09:19 PM
When using a ball joint splitter, don't just keep winding it up tighter and tighter (this assumes you are using a scissors type).
Get another splitter. Once its in position and got some pressure on the stud, tap the end of the splitter over the stud. You will probably find this will release it. If it does put another turn on the ball joint splitter and repeat. You will most likely find the splitter has become slacker anyway which is a sign that things are moving.
I have only ever had one ball joint which I couldn't split using the above method.
Posted 23 August 2014 - 09:48 PM
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
