Revotec Fan - Update
18 replies to this topic
#16 racingbob
racingbob
  • 3,061 posts
Posted 07 September 2014 - 08:36 AM
theres no bypass hose on the car
don't realy know whats going on
all I know is before it was running at 70
now runs at 80 but goes to 90 sometimes
and its definitely 88 stat in there
what you think I should do
where would you like to see it run
#17 l_jonez
l_jonez
  • 1,453 posts
Posted 07 September 2014 - 09:42 AM
For optimum thermal efficiency it should be running around the 86-90 mark. This will mean that the thermostat will be opening and closing as required. The rad should cool the water a couple of degrees purely by convection but to keep safe the fan should kick in about 90 degrees to stop the temps increasing any further.
#18 racingbob
racingbob
  • 3,061 posts
Posted 07 September 2014 - 09:49 AM
so you recommend changing fan to come on at 90 for a 88 stat
or if I want it to run bit cooler than that put in a 82 stat
#19 l_jonez
l_jonez
  • 1,453 posts
Posted 07 September 2014 - 02:58 PM
Yep set it to about 90, you could set it at 88 if you like as a couple of degrees won't make much difference.
There's a few degrees inaccuracies in the stat and sensors.
If you want it to run a bit cooler then fit a 82 stat and set the rad at roughly 84 degrees
